Problem with tone() within if()
Good day everyone,
I have this code and was wondering if any of you can tell me why my tone(12,450,500); does not execute within the if() statement BUT only in the void setup() .... ?
int led = 13;
int incomingByte = 0;
    pinMode(led, OUTPUT);
//tone(12,450,500);
	if (Serial.available() > 0) {
		incomingByte = Serial.read();
		if (incomingByte == 48)
                        tone(12,450,500);
                 	digitalWrite(led, HIGH);
                        digitalWrite(led, LOW);
if (incomingByte == '0')
What are you sending?
I am Reading a byte sent from my PC over the serial port and then I send a signal to pin 13 ...
What are you sending from the PC?
When a test such as
does not work as expected then it is a good idea to print what you are testing to see if its value is what you think it should be.
Its a zero ...
Not 48 then...
Mind you, 48 is the decimal ASCII value for zero.
Precisely ....
Its a zero
Not 48 then..
Precisely ....
What application is sending from the PC?
Certainly when I run your code from the IDE and the associated serial monitor I can see 48 for the entered 0, and can confirm both the led and the tone.
Arduino. I am running the code in the Arduino IDE ... Can I just make sure I understand correctly cattledog, does tone work on your Arduino (The tone() within the IF function)
You realize that the serial monitor doesn't send anything until you press , right?
I should at the very least hear a tone from the speaker when I run the code via Arduino IDE .... even before I program any operating system commands or any external commands then surely I should be able to hear the speaker ?!
The_Crow:
What code are you referring to ? The code in your original post has no tone() command that does not depend on suitable serial input being received. Does the LED turn on/off even though you don't hear the tone ?
If you have tried some test code then please post it and describe how the speaker is wired.
Yes. I confirmed it by running the output of the tone pin to an interrupt pin and counting the cycles from the tone output.
I did not use a speaker or buzzer. I would check out the wiring and your "speaker".
Here is the test code I ran. Jumper pin 12 to pin 2. Open the serial monitor, choose "no line ending" enter 0 and click the send button(or enter on your keyboard) . The led blinks and you will see a count of 225 on the monitor.
int led = 13;
volatile int count;
void countPulses()
  count++;
  attachInterrupt(0, countPulses, RISING);
  //tone(12,450,500);
      tone(12, 450, 500);
      noInterrupts();
      int readCount = count;
      count = 0;
      interrupts();
      Serial.println(readCount);
