Hi All.
I tested method of linking betweene to two Arduino Nano: the first as SPI Master, the second as SPI Slave.
This method was bescriebed by Nick Gammon Gammon Forum : Electronics : Microprocessors : SPI - Serial Peripheral Interface - for Arduino.
In my test Master sends to Slave an array of structures(40 bytes) and then receves from slave an array of structures(8 bytes). So, test works good exept anytime Master receives from Slave structure vith values
{0, 0, 0, 0, 0, 0, 0, 0}. I has couldn't find the reason of such behaviour. Belowe are shown scetches of Master and Slave Arduinos and fragments of outputs prining an in concole.
Master:________________________
#include <SPI.h>
typedef struct
uint8_t comnd;
}Set;
Set set[8];
typedef struct
uint8_t Vstat = 1;
uint16_t Vbat = 307;
uint8_t Sen = 38;
int8_t rssi = -57;
}Stat;
Stat stat[8];
void setup (void)
Serial.begin(38400);
digitalWrite(SS, HIGH); // ensure SS stays high for now
// Put SCK, MOSI, SS pins into output mode
// also put SCK, MOSI into LOW state, and SS into HIGH state.
// Then put SPI hardware into Master mode and turn SPI on
SPI.begin ();
// Slow down the master a bit
SPI.setClockDivider(SPI_CLOCK_DIV8);
} // end of setup
byte transferAndWait (const byte what)
byte a = SPI.transfer (what);
delayMicroseconds (10);
return a;
} // end of transferAndWait
long Tbegin;
void loop (void)
char c;
uint8_t lenth, j = 0;
uint8_t buf[40];
long temp, tbeg = micros();
//convering of array of structures in array of bytes
for (uint8_t i = 0; i < 8; i++)
buf[i * 5 + 0] = stat[i].Vstat;
buf[i * 5 + 1] = stat[i].Vbat >> 8;
buf[i * 5 + 2] = stat[i].Vbat & 0x00FF;
buf[i * 5 + 3] = stat[i].Sen;
buf[i * 5 + 4] = stat[i].rssi;
Serial.print("Tconv="); Serial.println(micros() - tbeg);
Serial.print(buf[i * 5]); Serial.print(" ");
Serial.print(buf[i * 5 + 1]); Serial.print(" ");
Serial.print(buf[i * 5 + 2]); Serial.print(" ");
Serial.print(buf[i * 5 + 3]); Serial.print(" ");
Serial.println(buf[i * 5 + 4]);
lenth = sizeof(buf);
Serial.print("Lenth="); Serial.println(lenth);
tbeg = micros();
// enable Slave Select
digitalWrite(SS, LOW); // SS is pin 10
//Send to Slave command: Send(Satus)
transferAndWait('S');
//transferAndWait (10);
for (uint8_t i = 0; i < lenth; i++)
transferAndWait(buf[i]);
transferAndWait(0);
// SPI.transfer (buf);
// delayMicroseconds (20);
// disable Slave Select
//Serial.print("Ttransf="); Serial.println(micros() - tbeg);
delayMicroseconds (200);
//delay(1);
//Send to Slave command Send(Satus)
transferAndWait('R');
transferAndWait(0);
set[i].comnd = transferAndWait(0);
temp = micros() - tbeg;
Serial.print("Ttransf="); Serial.println(temp);
Serial.print(set[i].comnd); Serial.print(" ");
Serial.flush();
delay (2000); // 2 seconds delay
} // end of loop
Slave_____________________________
#include <SPI.h>
typedef struct
uint8_t comnd;
}Set;
Set set[8] = {1, 2, 3, 4, 5, 6, 7, 8};
typedef struct
uint8_t Vstat;
uint16_t Vbat;
uint8_t Sen;
int8_t rssi;
}Stat;
Stat stat[8];
char buf [100];
bool Fl_buf_done = 0;
volatile byte command = 0;
void setup (void)
Serial.begin (38400); // debugging
// have to send on master in, *slave out*
pinMode(MISO, OUTPUT);
pinMode(9, OUTPUT); //high level on pin9 indicate processing
//of SPI interrupt (for serial analizer Channel 4)
// turn on SPI in slave mode
SPCR |= _BV(SPE);
// turn on interrupts
SPCR |= _BV(SPIE);
Serial.println("Setup done");
} // end of setup
// SPI interrupt routine------------------
ISR (SPI_STC_vect)
byte c = SPDR;
static uint8_t i;
noInterrupts(); //disable all interrupts
switch (command)
case 0: // no command? then this is the command
command = c;
i = 0;
Fl_buf_done = 0;
SPDR = 0;
case 'S': // receive array from Master
buf[i] = c;
i++;
if (i > 39)
Fl_buf_done = 1;
//Pin9 for indication in serial analizer
digitalWrite(9, HIGH);
digitalWrite(9, LOW);
case 'R': //send array to Master
if (bitRead(SPSR, 6))
SPDR = set[i].comnd;
i++;
default :
} // end of switch
interrupts(); //enable interrupt again
} // end of interrupt routine SPI_STC_vect
// main loop - wait for flag set in interrupt routine
void loop (void)
// if SPI not active, clear current command
if (digitalRead (SS) == HIGH)
command = 0;
if (Fl_buf_done)
Serial.print(buf[i * 5], DEC); Serial.print(" ");
Serial.print(buf[i * 5 + 1], DEC); Serial.print(" ");
Serial.print(buf[i * 5 + 2], DEC); Serial.print(" ");
Serial.print(buf[i * 5 + 3], DEC); Serial.print(" ");
Serial.println(buf[i * 5 + 4], DEC);
Serial.flush();
//clear buffer
for (uint8_t k = 0; k < 40; k++)
buf[k] = 0;
Fl_buf_done = 0;
} // end of loop
Output of Master:___________________________
Tconv=72
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
Lenth=40
Ttransf=984 must be : 1 2 3 4 5 6 7 8
0 0 0 0 0 0 0 0 <<-----------------------------------
Tconv=72 but receved: 0 0 0 0 0 0 0 0
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
Lenth=40
Ttransf=984
1 2 3 4 5 6 7 8
Tconv=72
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
1 1 51 38 199
Lenth=40
Ttransf=984
1 2 3 4 5 6 7 8
Tconv=68
1 1 51 38 199
1 1 51 38 199
Slave (here all is Ok):____________________
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
1 1 51 38 -57
What may be the reason of such behaviour?
Thank You.
