Problem with uploading
Hello everyone. During uploading I get this message. Please help.
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM3
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "\.\COM3": Odmowa dost�pu.
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
You might get this error in IDE 2.x (but you posted in IDE 1.x) if you have the serial monitor open.
avrdude: ser_open(): can’t open device : access is denied
  1. Make sure the correct port is selected in Tools > Port.
  2. Close other instances of Arduino IDE, serial monitors, and other software that may be blocking the port.
  3. Restart your computer.
  4. See Find and stop process blocking a port.
Now he gave me this error
     Using Port                    : COM3
     AVR Part                      : ATmega328P
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : Arduino
     Description     : Arduino
     Hardware Version: 3
     Firmware Version: 4.4
     Vtarget         : 0.3 V
     Varef           : 0.3 V
     Oscillator      : 28.800 kHz
     SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\admin\AppData\Local\Temp\arduino_build_687935/ArduinoISP.ino.hex"
avrdude: writing flash (4354 bytes):
Writing | ################################################## | 100% 0.63s
avrdude: 4354 bytes of flash written
avrdude: verifying flash memory against C:\Users\admin\AppData\Local\Temp\arduino_build_687935/ArduinoISP.ino.hex:
avrdude: load data flash data from input file C:\Users\admin\AppData\Local\Temp\arduino_build_687935/ArduinoISP.ino.hex:
avrdude: input file C:\Users\admin\AppData\Local\Temp\arduino_build_687935/ArduinoISP.ino.hex contains 4354 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.49s
avrdude: verifying ...
avrdude: 4354 bytes of flash verified
Why do you think that that is an error. Please do not be confused by the fact that the colour is red.
:+1:
That means it's OK
I'm just starting out and I thought red meant an error. Thanks a lot.
It does not mean that it's OK; below a failed upload to a Nano.
         System wide configuration file is "C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM9
avrdude: ser_open(): can't open device "\\.\COM9": Access is denied.
It can also happen in IDE1.x if something else is connected to the COM port.
Topic to close. Problem solved. Thank you all for your help.
