Problemă apărută la exportul pe placa Ideaspark Weather Station. Mă poate ajuta cineva?
#include <Arduino.h>
#if defined(ESP8266)
#include <ESP8266WiFi.h>
#include <coredecls.h>
#else
#include <WiFi.h>
#endif
#include <ESP8266HTTPClient.h>
#include "JsonListener.h"
#include <time.h>
#include <sys/time.h>
#include "SSD1306Wire.h"
#include "OLEDDisplayUi.h"
#include "Wire.h"
#include "OpenWeatherMapCurrent.h"
#include "OpenWeatherMapForecast.h"
#include "WeatherStationFonts.h"
#include "WeatherStationImages.h"
/******************** Begin Settings ********************/
 * WIFI Settings
const char* WiFi_Name = "Razvan";
const char* WiFi_Password = "Simona18";
WiFiClient client;
 * OpenWeatherMap Settings
 * Sign up here to get an API key:  https://docs.thingpulse.com/how-tos/openweathermap-key/
const boolean IS_METRIC = true;
String OPEN_WEATHER_MAP_APP_ID = "a0254154e8f2fff62d6b63dcff9653ed";
/*Go to https://openweathermap.org/find?q= and search for a location. Go through the
result set and select the entry closest to the actual location you want to display
data for. It'll be a URL like https://openweathermap.org/city/2657896. The number
at the end is what you assign to the constant below.
String OPEN_WEATHER_MAP_LOCATION_ID = "2657896";
/*Pick a language code from this list:
Arabic - ar, Bulgarian - bg, Catalan - ca, Czech - cz, German - de, Greek - el,English - en, Persian (Farsi) - fa, Finnish - fi, French - fr, Galician - gl,
Croatian - hr, Hungarian - hu, Italian - it, Japanese - ja, Korean - kr,Latvian - la, Lithuanian - lt, Macedonian - mk, Dutch - nl, Polish - pl,
Portuguese - pt, Romanian - ro, Russian - ru, Swedish - se, Slovak - sk,Slovenian - sl, Spanish - es, Turkish - tr, Ukrainian - ua, Vietnamese - vi,Chinese Simplified - zh_cn, Chinese Traditional - zh_tw.
String OPEN_WEATHER_MAP_LANGUAGE = "en";
const uint8_t MAX_FORECASTS = 4;
// Adjust according to your language
const String WDAY_NAMES[] = {"SUN", "MON", "TUE", "WED", "THU", "FRI", "SAT"};
const String MONTH_NAMES[] = {"JAN", "FEB", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP", "OCT", "NOV", "DEC"};
OpenWeatherMapCurrentData   currentWeather;
OpenWeatherMapCurrent       currentWeatherClient;
OpenWeatherMapForecastData  forecasts[MAX_FORECASTS];
OpenWeatherMapForecast      forecastClient;
 * Begin 0.96 inch SSD1306 OLED Settings
 * (0.96'' OLED integrated on ESP8266 board, ESP8266 D6 connect OLED SDA Port and D5 connect OLED SCL Port can't be changed)
#define OLED_SDA_Pin 12   //ESP8266 D6 connect 0.96'' OLED SDA Port
#define OLED_SCL_Pin 14   //ESP8266 D5 connect 0.96'' OLED SCL Port
const int I2C_DISPLAY_ADDRESS = 0x3c;
SSD1306Wire     display(I2C_DISPLAY_ADDRESS, OLED_SDA_Pin, OLED_SCL_Pin);
OLEDDisplayUi   ui( &display );
void drawProgress(OLEDDisplay *display, int percentage, String label);
void updateData(OLEDDisplay *display);
void drawDateTime(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
void drawCurrentWeather(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
void drawForecast(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y);
void drawForecastDetails(OLEDDisplay *display, int x, int y, int dayIndex);
void drawHeaderOverlay(OLEDDisplay *display, OLEDDisplayUiState* state);
 * Time Settings
#define TZ              2       // (utc+) TZ in hours
#define DST_MN          60      // use 60mn for summer time in some countries
#define TZ_MN           ((TZ)*60)
#define TZ_SEC          ((TZ)*3600)
#define DST_SEC         ((DST_MN)*60)
time_t now;
const int UPDATE_INTERVAL_SECS = 20 * 60; // Update every 20 minutes
// flag changed in the ticker function every 10 minutes
bool readyForWeatherUpdate = false;
String lastUpdate = "--";
long timeSinceLastWUpdate = 0;
void setReadyForWeatherUpdate();//declaring prototypes
// Add frames
// this array keeps function pointers to all frames
// frames are the single views that slide from right to left
FrameCallback frames[] = { drawDateTime, drawCurrentWeather, drawForecast };
int numberOfFrames = 3;
OverlayCallback overlays[] = { drawHeaderOverlay };
int numberOfOverlays = 1;
/******************** End Settings ********************/
  //initialize 0.96'' OLED Dispaly
  display.init();
  display.clear();
  display.display();
  WiFi.begin(WiFi_Name, WiFi_Password);
  int counter = 0;
    Serial.print(".");
    display.clear();
    display.drawString(10, 10, "Connecting to WiFi");
    display.drawXbm(46, 30, 8, 8, counter % 3 == 0 ? activeSymbole : inactiveSymbole);
    display.drawXbm(60, 30, 8, 8, counter % 3 == 1 ? activeSymbole : inactiveSymbole);
    display.drawXbm(74, 30, 8, 8, counter % 3 == 2 ? activeSymbole : inactiveSymbole);
    display.display();
    counter++;
  // Get time from network time service
  configTime(TZ_SEC, DST_SEC, "pool.ntp.org");
  ui.setTargetFPS(30);
  ui.setActiveSymbol(activeSymbole);
  ui.setInactiveSymbol(inactiveSymbole);
  // You can change this to
  // TOP, LEFT, BOTTOM, RIGHT
  ui.setIndicatorPosition(BOTTOM);
  // Defines where the first frame is located in the bar.
  ui.setIndicatorDirection(LEFT_RIGHT);
  // You can change the transition that is used
  // SLIDE_LEFT, SLIDE_RIGHT, SLIDE_TOP, SLIDE_DOWN
  ui.setFrameAnimation(SLIDE_LEFT);
  ui.setFrames(frames, numberOfFrames);
  ui.setOverlays(overlays, numberOfOverlays);
  // Inital UI takes care of initalising the display too.
  ui.init();
  Serial.println("");
  updateData(&display);
  if (millis() - timeSinceLastWUpdate > (1000L*UPDATE_INTERVAL_SECS)) {
    timeSinceLastWUpdate = millis();
  if (readyForWeatherUpdate && ui.getUiState()->frameState == FIXED) {
  int remainingTimeBudget = ui.update();
  if (remainingTimeBudget > 0) {
    // You can do some work here
    // Don't do stuff if you are below your
    // time budget.
    delay(remainingTimeBudget);
void drawProgress(OLEDDisplay *display, int percentage, String label) {
  display->clear();
  display->setTextAlignment(TEXT_ALIGN_CENTER);
  display->setFont(ArialMT_Plain_10);
  display->drawString(64, 10, label);
  display->drawProgressBar(2, 28, 124, 10, percentage);
  display->display();
void updateData(OLEDDisplay *display) {
  drawProgress(display, 10, "Updating time...");
  drawProgress(display, 30, "Updating weather...");
  currentWeatherClient.setMetric(IS_METRIC);
  currentWeatherClient.setLanguage(OPEN_WEATHER_MAP_LANGUAGE);
  currentWeatherClient.updateCurrentById(&currentWeather, OPEN_WEATHER_MAP_APP_ID, OPEN_WEATHER_MAP_LOCATION_ID);
  drawProgress(display, 50, "Updating forecasts...");
  forecastClient.setMetric(IS_METRIC);
  forecastClient.setLanguage(OPEN_WEATHER_MAP_LANGUAGE);
  uint8_t allowedHours[] = {12};
  forecastClient.setAllowedHours(allowedHours, sizeof(allowedHours));
  forecastClient.updateForecastsById(forecasts, OPEN_WEATHER_MAP_APP_ID, OPEN_WEATHER_MAP_LOCATION_ID, MAX_FORECASTS);
  drawProgress(display, 100, "Done...");
void drawDateTime(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
  now = time(nullptr);
  struct tm* timeInfo;
  timeInfo = localtime(&now);
  char buff[16];
  String date = WDAY_NAMES[timeInfo->tm_wday];
  sprintf_P(buff, PSTR("%s, %02d/%02d/%04d"), WDAY_NAMES[timeInfo->tm_wday].c_str(), timeInfo->tm_mday, timeInfo->tm_mon+1, timeInfo->tm_year + 1900);
  display->drawString(64 + x, 5 + y, String(buff));
  display->setFont(ArialMT_Plain_24);
  sprintf_P(buff, PSTR("%02d:%02d:%02d"), timeInfo->tm_hour, timeInfo->tm_min, timeInfo->tm_sec);
  display->drawString(64 + x, 15 + y, String(buff));
  display->setTextAlignment(TEXT_ALIGN_LEFT);
void drawCurrentWeather(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
  display->drawString(64 + x, 38 + y, currentWeather.description);
  String temp = String(currentWeather.temp, 1) + (IS_METRIC ? "°C" : "°F");
  display->drawString(60 + x, 5 + y, temp);
  display->setFont(Meteocons_Plain_36);
  display->drawString(32 + x, 0 + y, currentWeather.iconMeteoCon);
void drawForecast(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
  drawForecastDetails(display, x, y, 0);
  drawForecastDetails(display, x + 44, y, 1);
  drawForecastDetails(display, x + 88, y, 2);
void drawForecastDetails(OLEDDisplay *display, int x, int y, int dayIndex) {
  time_t observationTimestamp = forecasts[dayIndex].observationTime;
  timeInfo = localtime(&observationTimestamp);
  display->drawString(x + 20, y, WDAY_NAMES[timeInfo->tm_wday]);
  display->setFont(Meteocons_Plain_21);
  display->drawString(x + 20, y + 12, forecasts[dayIndex].iconMeteoCon);
  String temp = String(forecasts[dayIndex].temp, 0) + (IS_METRIC ? "°C" : "°F");
  display->drawString(x + 20, y + 34, temp);
void drawHeaderOverlay(OLEDDisplay *display, OLEDDisplayUiState* state) {
  char buff[14];
  sprintf_P(buff, PSTR("%02d:%02d"), timeInfo->tm_hour, timeInfo->tm_min);
  display->setColor(WHITE);
  display->drawString(0, 54, String(buff));
  display->setTextAlignment(TEXT_ALIGN_RIGHT);
  display->drawString(128, 54, temp);
  display->drawHorizontalLine(0, 52, 128);
void setReadyForWeatherUpdate() {
  Serial.println("Setting readyForUpdate to true");
  readyForWeatherUpdate = true;
What is your question?
You should use English in most parts of this forum.
Please edit the title of your post above and replace it with English.
Nu mulți oameni pe aici vorbesc româna, dar Google se îmbunătățește mereu.
The translator gave me this: Problem of export on the Ideaspark Weather Station board. Can anyone help me?
Without knowing what your problem is and what hardware you are using the best answer would be a SWAG (Scientific Wild Assuming Guess). Please add details so we can understand what you want. Also posting an annotated schematic of your project helps. If it is just an Arduino board, which one and how are you powering it.
Traducătorul mi-a dat următoarele: Problemă de export pe placa stației meteo Ideaspark. Mă poate ajuta cineva? Fără a ști care este problema ta și ce hardware folosești, cel mai bun răspuns ar fi un SWAG (Scientific Wild Assuming Guess). Vă rugăm să adăugați detalii pentru a putea înțelege ce doriți. De asemenea, postarea unei scheme adnotate a proiectului tău ajută. Dacă este doar o placă Arduino, care și cum o alimentați.
