Problema con lo sketch dell'arduino cloud
Ciao a tutti sono nuovo e sto provando a governare un servo motore in remoto dal cloud ma lo stesso codice che uso nell'IDE è considerato come errore.
/usr/local/bin/arduino-cli compile --fqbn arduino:mbed_giga:giga:split=100_0,target_core=cm7 --build-cache-path /tmp --output-dir /tmp/2246149042/build --build-path /tmp/arduino-build-90C1DEA221394975E2DE6347505067FD  /tmp/2246149042/Untitled_jul02b
/tmp/2246149042/Untitled_jul02b/Untitled_jul02b.ino:3:7: error: no matching function for call to 'Servo::Servo()'
 Servo myservo;
In file included from /tmp/2246149042/Untitled_jul02b/Untitled_jul02b.ino:2:0:
/home/builder/Arduino/libraries/vovagorodok_servo_1_0_0/src/Servo.h:7:5: note: candidate: Servo::Servo(uint8_t, int, bool)
     Servo(uint8_t pin, int degree, bool activeState = HIGH);
/home/builder/Arduino/libraries/vovagorodok_servo_1_0_0/src/Servo.h:7:5: note:   candidate expects 3 arguments, 0 provided
/home/builder/Arduino/libraries/vovagorodok_servo_1_0_0/src/Servo.h:4:7: note: candidate: constexpr Servo::Servo(const Servo&)
 class Servo
/home/builder/Arduino/libraries/vovagorodok_servo_1_0_0/src/Servo.h:4:7: note:   candidate expects 1 argument, 0 provided
/home/builder/Arduino/libraries/vovagorodok_servo_1_0_0/src/Servo.h:4:7: note: candidate: constexpr Servo::Servo(Servo&&)
/tmp/2246149042/Untitled_jul02b/Untitled_jul02b.ino: In function 'void setup()':
/tmp/2246149042/Untitled_jul02b/Untitled_jul02b.ino:17:11: error: 'class Servo' has no member named 'attach'
   myservo.attach(5);
/tmp/2246149042/Untitled_jul02b/Untitled_jul02b.ino: In function 'void loop()':
/tmp/2246149042/Untitled_jul02b/Untitled_jul02b.ino:24:13: error: 'class Servo' has no member named 'write'
     myservo.write(180);
/tmp/2246149042/Untitled_jul02b/Untitled_jul02b.ino:26:13: error: 'class Servo' has no member named 'write'
     myservo.write(0);
/tmp/2246149042/Untitled_jul02b/Untitled_jul02b.ino: At global scope:
/tmp/2246149042/Untitled_jul02b/Untitled_jul02b.ino:32:1: error: expected declaration before '}' token
Multiple libraries were found for "WiFi.h"
  Used: /home/builder/.arduino15/packages/arduino/hardware/mbed_giga/4.1.3/libraries/WiFi
  Not used: /home/builder/opt/libraries/wifi_1_2_7
  Not used: /home/builder/opt/libraries/wifiespat_1_4_4
  Not used: /home/builder/opt/libraries/betterwifinina_1_3_0
  Not used: /home/builder/opt/libraries/wifinina_1_8_14
  Not used: /home/builder/opt/libraries/indhilib_3_0_5
  Not used: /home/builder/opt/libraries/vega_wifinina_1_0_1
  Not used: /home/builder/opt/libraries/seeed_arduino_rpcwifi_1_1_0
  Not used: /home/builder/opt/libraries/nina_wi_fi_1_0_1
  Not used: /home/builder/opt/libraries/da16200_wi_fi_library_for_arduino_1_1_0
Multiple libraries were found for "ECCX08.h"
  Used: /home/builder/opt/libraries/arduinoeccx08_1_3_8
  Not used: /home/builder/opt/libraries/rak5814_atecc608a_1_0_0
Multiple libraries were found for "Servo.h"
  Used: /home/builder/opt/libraries/vovagorodok_servo_1_0_0
  Not used: /home/builder/opt/libraries/rokitsmart_1_0_9
  Not used: /home/builder/opt/libraries/esp32_esp32s2_analogwrite_5_0_2
  Not used: /home/builder/opt/libraries/evive_2_0_3
  Not used: /home/builder/opt/libraries/printoo_library_1_0_2
  Not used: /home/builder/opt/libraries/servo_1_2_2
  Not used: /home/builder/opt/libraries/servoesp32_1_1_1
  Not used: /home/builder/opt/libraries/microbitv2_hhs_0_1_6
  Not used: /home/builder/opt/libraries/xmc_servo_1_0_1
  Not used: /home/builder/opt/libraries/servoesp32fix_1_1_2
Multiple libraries were found for "Wire.h"
  Used: /home/builder/.arduino15/packages/arduino/hardware/mbed_giga/4.1.3/libraries/Wire
  Not used: /home/builder/opt/libraries/flexwire_1_2_1
Error during build: exit status 1
Questo è l'errore che ottengo al seguente codice:
#include <Servo.h>
Servo myservo;
#include "thingProperties.h"
  delay(1500);
  initProperties();
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  myservo.attach(5);
  ArduinoCloud.update();
  if (digitalRead(botton)==HIGH){
    myservo.write(180);
  }else{
    myservo.write(0);
Perdonatemi per il lungo messaggio o errori nell'indicazione del codice.
Grazie in anticipo per l'aiuto.
Buongiorno e benvenuto nella sezione Italiana del forum,
cortesemente, come prima cosa, leggi attentamente il REGOLAMENTO di detta sezione, (... e, per evitare future possibili discussioni/incomprensioni, prestando molta attenzione al punto 15), dopo di che, come da suddetto regolamento, fai la tua presentazione NELL'APPOSITA DISCUSSIONE (... quello che vedi in blu è un link, fai click su di esso per raggiungere la discussione) spiegando bene quali esperienze hai in elettronica e programmazione, affinché noi possiamo conoscere la tua esperienza ed esprimerci con termini adeguati.
Detto questo, come richiesto al punto 7 del succitato regolamento, per favore edita il tuo post qui sopra (quindi NON scrivendo un nuovo post, ma utilizzando il bottone a forma di piccola matita :pencil2: che si trova in basso del tuo post), seleziona la parte di codice e premi l'icona <code/> nella barra degli strumenti per contrassegnarla come codice. Inoltre, così com'è, non è molto leggibile ... assicurati di averlo correttamente indentato nell'IDE prima di inserirlo (questo lo si fa premendo ctrlT su un PC o cmd T su un Mac, sempre all'interno del IDE).
Grazie,
Guglielmo
P.S.: Ti ricordo che, purtroppo, fino a quando non sarà fatta la presentazione nell’apposita discussione e sistemato il codice come indicato, nel rispetto del regolamento nessuno ti risponderà (eventuali risposte o tuoi ulteriori post, verrebbero temporaneamente nascosti), quindi ti consiglio di farla al più presto. :wink:
Che hardware stai utilizzando e che librerie?
Non mi sembra tu stia utilizzando la libreria "Servo" ufficiale ... :roll_eyes:
Guglielmo
Sto utilizzando un arduino giga r1 wi fi.
Come libreria invece ho utilizzato la stessa libreria che uso nell'IDE cercandola prima nel cloud e includendola dopo averla trovata.
Più nello specifico ho impostato "All devices" nella ricerca della libreria.
Matteo
Questa è la libreria che arduino ha selezionato:
Questa è la lista delle librerie installate:
Ciao.
Ok grazie per le definizioni.
Inoltre quando verifico il codice, l'errore evidenziato risulta la riga dove, precedentemente al "void setup", definisco il nome del servo motore con l'espressione "myservo".
Matteo.
Ho provato anche con un’altra libreria ma non la considerava giusta.
