Problème avec capteur de température
Bonjour,
Je viens d'acheter un capteur ds18b20.
Pour l'essayer, j'ai copié de programme : Thermomètre de précision basé sur un capteur de température One-wire de type DS18B20 (affichage série USB) - Mon Club Elec
Mais l'ide m'affiche plusieurs erreurs :
C:\Users\admin\Documents\arduino-1.0\libraries\OneWire\OneWire.cpp:85:24: error: WConstants.h: No such file or directory
C:\Users\admin\Documents\arduino-1.0\libraries\OneWire\OneWire.cpp: In constructor 'OneWire::OneWire(uint8_t)':
C:\Users\admin\Documents\arduino-1.0\libraries\OneWire\OneWire.cpp:93: error: 'digitalPinToBitMask' was not declared in this scope
C:\Users\admin\Documents\arduino-1.0\libraries\OneWire\OneWire.cpp:94: error: 'digitalPinToPort' was not declared in this scope
C:\Users\admin\Documents\arduino-1.0\libraries\OneWire\OneWire.cpp:94: error: 'portInputRegister' was not declared in this scope
C:\Users\admin\Documents\arduino-1.0\libraries\OneWire\OneWire.cpp: In member function 'uint8_t OneWire::reset()':
C:\Users\admin\Documents\arduino-1.0\libraries\OneWire\OneWire.cpp:127: error: 'delayMicroseconds' was not declared in this scope
C:\Users\admin\Documents\arduino-1.0\libraries\OneWire\OneWire.cpp:134: error: 'delayMicroseconds' was not declared in this scope
C:\Users\admin\Documents\arduino-1.0\libraries\OneWire\OneWire.cpp: In member function 'void OneWire::write_bit(uint8_t)':
C:\Users\admin\Documents\arduino-1.0\libraries\OneWire\OneWire.cpp:157: error: 'delayMicroseconds' was not declared in this scope
C:\Users\admin\Documents\arduino-1.0\libraries\OneWire\OneWire.cpp:165: error: 'delayMicroseconds' was not declared in this scope
C:\Users\admin\Documents\arduino-1.0\libraries\OneWire\OneWire.cpp: In member function 'uint8_t OneWire::read_bit()':
C:\Users\admin\Documents\arduino-1.0\libraries\OneWire\OneWire.cpp:185: error: 'delayMicroseconds' was not declared in this scope
Je ne comprend pas... D'après ce que j'en tire, l'ide n'arrive pas à lire la librairie. Me tromp-je ? :stuck_out_tongue:
Quelqu'un a une idée ?
Cordialement
Quentin
Quelle version d'IDE, quel OS ?
Bonsoir,
Il s'agit de l'IDE 1.0 sous windows 7.
Essaye avec la version 022 ou 023.
Cela fonctionne en 1-wire ?
Certaines librairies ne fonctionnent plus avec la version 1.0.
Je viens de tester ton code : sous 1.0 il fonctionne chez moi
// --- Programme Arduino ---
// Copyright X. HINAULT - Créé le 11/04/2010
// www.mon-club-elec.fr
//  Code sous licence GNU GPL :
//  This program is free software: you can redistribute it and/or modify
//  it under the terms of the GNU General Public License as published by
//  the Free Software Foundation, either version 3 of the License,
//  or any later version.
//  This program is distributed in the hope that it will be useful,
//  but WITHOUT ANY WARRANTY; without even the implied warranty of
//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
//  GNU General Public License for more details.
//  You should have received a copy of the GNU General Public License
//  along with this program.  If not, see <http://www.gnu.org/licenses/>.
// --- Que fait ce programme ? ---
/* réalise un thermomètre de précision avec affichage
du résultat dans la fenêtre Terminal série,
à l'aide d'un capteur de température One-wire de type DS18B20.
Une mesure est effectuée toute les secondes. */
// --- Fonctionnalités utilisées ---
// Utilise la connexion série vers le PC
// Utilise un ou plusieurs capteurs One Wire
// --- Circuit à réaliser ---
// Connexion série entre la carte Arduino et le PC (utilise les broches 0 et 1)
// Connecter  sur la broche 2 la broche de données du capteur One Wire
//**************** Entête déclarative *******
// A ce niveau sont déclarées les librairies, les constantes, les variables...
// --- Inclusion des librairies utilisées ---
#include <OneWire.h> // librairie pour capteur OneWire
// --- Déclaration des constantes ---
//---- code des instructions du capteur
const int modeLecture=0xBE;
const int lancerMesure=0x44;
// --- constantes des broches ---
const int broche_OneWire=10; //declaration constante de broche
// --- Déclaration des variables globales ---
byte data[12]; // Tableau de 12 octets pour lecture des 9 registres de RAM et des 3 registres d'EEPROM du capteur One Wire
byte adresse[8]; // Tableau de 8 octets pour stockage du code d'adresse 64 bits du composant One Wire
float ma_tempetf=0.0;
// --- Déclaration des objets utiles pour les fonctionnalités utilisées ---
OneWire  capteur(broche_OneWire);  // crée un objet One Wire sur la broche voulue
//**************** FONCTION SETUP = Code d'initialisation *****
// La fonction setup() est exécutée en premier et 1 seule fois, au démarrage du programme
void setup()   { // debut de la fonction setup()
// --- ici instructions à exécuter au démarrage ---
Serial.begin(115200); // initialise connexion série à 115200 bauds
// IMPORTANT : régler le terminal côté PC avec la même valeur de transmission
// --- initialisation du capteur DS18B20 ------
capteurInit(); // appel de la fonction d'initialisation du capteur - au début seulement
// prise en compte du premier capteur trouvé
} // fin de la fonction setup()
//*************** FONCTION LOOP = Boucle sans fin = coeur du programme *************
// la fonction loop() s'exécute sans fin en boucle aussi longtemps que l'Arduino est sous tension
void loop(){ // debut de la fonction loop()
ma_tempetf=capteurMesureTemp(); // appel de la fonction de mesure - renvoie une valeur float
Serial.print ("Temperature = ");
Serial.print (ma_tempetf,2);
Serial.println (" Degres Celsius. ");
} // fin de la fonction loop() - le programme recommence au début de la fonction loop sans fin
//*************** Autres Fonctions du programme *************
//************************** fonction d'initialisation du capteur ****************
void capteurInit(void) // fonction qui ne reçoit rien et ne renvoie rien
// XXXXXXXXXXXXXXXXXXXXXX Détection du capteur présent sur la broche XXXXXXXXXXXXXXXXXXXXXXX
Serial.println("**** Detection du capteur **** ");
while (capteur.search(adresse)== false) // tant qu'aucun nouveau capteur est détecté
  // la fonction search renvoie la valeur FAUX si aucun élément 1-wire est trouvé.
  Serial.println("Aucun capteur 1-wire present sur la broche ! "); // affiche message + saut de ligne
  delay (1000); // pause 1 seconde
//la suite est exécutée seulement si un capteur est détecté
  // la fonction search renvoie la valeur VRAI si un élément 1-wire est trouvé.
  // Stocke son code d'adresse 16 bits dans le tableau adresse[8]
  // adresse envoyé à la fonction correspond à l'adresse de début du tableau adresse[8] déclaré ...
  Serial.print ("1 capteur 1-wire present avec code adresse 64 bits : ");
  //--- affichage des 64 bits d'adresse au format hexadécimal
   for(int i = 0; i < 8; i++) { // l'adresse renvoyée par la fonction search est stockée sur 8 octets
    if (adresse[i]<16) Serial.print('0'); // pour affichage des O poids fort au format hexadécimal
    Serial.print(adresse[i], HEX); // affiche 1 à 1 les 8 octets du tableau adresse au format hexadécimal
    Serial.print(" ");
  //---- test du type de capteur ----
  // le type du capteur est donné par le 1er octet du code adresse 64 bits
  // Valeur 0x28 pour capteur type DS18B20, 0x10 pour type DS18S20, 0x22 pour type DS1820
  if (adresse[0]==0x28)
    Serial.println ("Type du capteur present : Capteur temperature DS18B20.");
    Serial.println ("Le capteur present n'est pas un capteur de temperature DS18B20.");
  //----- contrôle du code CRC ----
  // le dernier octet de l'adresse 64bits est un code de contrôle CRC
  // à l'aide de la fonction crc8 on peut vérifier si ce code est valide
  if (capteur.crc8( adresse, 7) == adresse[7]) // vérification validité code CRC de l'adresse 64 bits
  // le code CRC de l'adresse 64 bits est le 8ème octet de l'adresse (index 7 du tableau)
    Serial.println ("Verification du code CRC de l'adresse 64 bits de ce capteur : VALIDE !");
    Serial.println ("Verification du code CRC de l'adresse 64 bits de ce capteur : NON VALIDE !");
  //------- message final détection ----
  Serial.println("----- fin de la recherche du capteur ----");
  Serial.println("");
//----------- fin de la fonction d'initialisation du capteur ----------
//-------------- fonction de mesure de la température ---------------
float capteurMesureTemp(void) { //fonction qui renvoie résultat float et ne reçoit rien
   //-------- variable locale de la fonction ----------
  int tempet=0; // variable pour resultat brute  de la mesure
  float tempetf=0.0; // variable pour resultat à virgule de la mesure
// XXXXXXXXXXXXXXXXXXXXXX Lancement d'une mesure et lecture du résultat XXXXXXXXXXXXXXXXXXXXXXX
 // Serial.println("**** Acquisition d'une mesure de la temperature **** ");
  // avant chaque nouvelle instruction, il faut :
  //    * initialiser le bus 1-wire
  //    * sélectionner le capteur détecté
  //    * envoyer l'instruction
//--------- lancer une mesure --------
  capteur.reset(); // initialise le bus 1-wire avant la communication avec un capteur donné
  capteur.select(adresse); // sélectionne le capteur ayant l'adresse 64 bits contenue dans le tableau envoyé à la fonction
  capteur.write(lancerMesure,1); // lance la mesure et alimente le capteur par la broche de donnée
//-------- pause d'une seconde -----
delay(1000);     // au moins 750 ms
           // il faudrait mettre une instruction capteur.depower ici, mais le reset va le faire
//---------- passer en mode LECTURE -------------
  capteur.write(modeLecture,1); // passe en mode lecture de la RAM du capteur
// ----------- lire les 9 octets de la RAM (appelé Scratchpad) ----
for ( int i = 0; i < 9; i++) {           // 9 octets de RAM stockés dans 9 octets
    data[i] = capteur.read();             // lecture de l'octet de rang i stocké dans tableau data
//----- caclul de la température mesurée (enfin!) ---------
data[1]=data[1] & B10000111; // met à 0 les bits de signes inutiles
tempet=data[1]; // bits de poids fort
tempet=tempet<<8;
tempet=tempet+data[0]; // bits de poids faible
// --- en mode 12 bits, la résolution est de 0.0625°C - cf datasheet DS18B20
tempetf=float(tempet)*6.25;
tempetf=tempetf/100.0;
return (tempetf);
// --------------- fin de la fonction de mesure de la température ----------
// --- Fin programme ---
Assures toi d'avoir bien installé la librairie
Edit : La librairie ici : http://www.pjrc.com/teensy/arduino_libraries/OneWire.zip
je suis du même avis que "Jean-François".
Pour ma part j'utilise cette library :
http://www.milesburton.com/Dallas_Temperature_Control_Library
Attention au mode "a-synchrone" qui doit être bien maîtrisé. :cold_sweat:
Bonjour,
Effectivement, le code marche sous l'ide 022.
Ça doit être un problème de librairie, car avec le lien de michel_b, ça fonctionne.
J’avais la librairie donnée sur mon club elec ( http://www.mon-club-elec.fr/pmwiki_reference_arduino/pmwiki.php?n=Main.LibrairieOneWire ).
Un grand merci à vous :slight_smile:
