Bonjour,
Depuis ce matin, après avoir mis à jour l'IDE Arduino et les cartes j'ai ce message :
fatal error: mbedtls/net.h: No such file or directory
est ce que quelqu'un pourrait m'aider ?
Merci d'avance,
Bonjour,
Merci d'avance,
Add the missing library with Library Manager.
voici le message d'erreur en sortie :
In file included from c:\Users\admin\Documents\Arduino\libraries\ESP32_Mail_Client\src/WiFiClientSecureESP32.h:55,
from c:\Users\admin\Documents\Arduino\libraries\ESP32_Mail_Client\src/ESP32_MailClient.h:38,
from C:\Users\admin\Documents\Arduino\Marauder_V1\Projet_TEMP_V4.ino:6:
c:\Users\admin\Documents\Arduino\libraries\ESP32_Mail_Client\src/ssl_client32.h:36:10: fatal error: mbedtls/net.h: No such file or directory
36 | #include "mbedtls/net.h"
compilation terminated.
exit status 1
Compilation error: exit status 1
you can help me ?
i have installed the package and same problem.
Show us the error log, ALL of it. In code tags.
Then you are doing something wrong, I showed you what is required, I can do no more.
sorry but can you write more precisely what to do, or maybe I did it wrong.
I installed the seeed package... via the manager
show me the library in the libraries directory, use a screen grab.
Ok, and what folders are inside Seeed_Arduino_mbedtls
Something is a little different right? Try just including net.h
I just tried the sample from that library, and your net.h include FAILS even if I specify the whole path. Very mysterious. I am stumped for the moment.
I tried #include "mbedtls/net.h" but same problem
Try this example in the Seeed_Arduino_mbedtls library
