Bonjour
alors j'ai un programme qui tourne sur une Arduino uno , mais je voudrais le mettre sur une Nano Evry pour gain de place et aussi pour la prise USB plus petite.
Mais impossible , j'ai une erreur a chaque vois et ça tourne en rond .
voici l'erreur qui ce répète
avrdude: jtagmkII_getsync(): sign-on command: status -1
je vous met au aussi le code , c'est pour station meteo pour un observatoire.
je vous la première partie ,car il a des onglets et je sais pas comment le mettre un dossier complet.
/* Firmware for a weather sensor device streaming the data as JSON documents.
Copyright (C) 2019 Wolfgang Reissenberger <sterne-jaeger@t-online.de>
This application is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public
License as published by the Free Software Foundation; either
version 2 of the License, or (at your option) any later version.
Based upon ideas from indiduinoMETEO (http://indiduino.wordpress.com).
#include <ArduinoJson.h>
Edit config.h to configure the attached sensors
#include "config.h"
#include "version.h"
// sensor measuring duration
struct {
unsigned long bme_read;
unsigned long dht_read;
unsigned long mlx90614_read;
unsigned long tsl237_read;
unsigned long tsl2591_read;
unsigned long davis_read;
} sensor_read;
Update all sensor data
void updateSensorData() {
// reset all timers
sensor_read = { 0, 0, 0, 0, 0, 0};
unsigned long start = 0;
#ifdef USE_DAVIS_SENSOR
start = millis();
readAnemometer();
sensor_read.davis_read = millis() - start;
#endif //USE_DAVIS_SENSOR
#ifdef USE_BME_SENSOR
start = millis();
updateBME();
sensor_read.bme_read = millis() - start;
#endif //USE_BME_SENSOR
#ifdef USE_DHT_SENSOR
start = millis();
updateDHT();
sensor_read.dht_read = millis() - start;
#endif //USE_DHT_SENSOR
#ifdef USE_MLX_SENSOR
start = millis();
updateMLX();
sensor_read.mlx90614_read = millis() - start;
#endif //USE_MLX_SENSOR
#ifdef USE_TSL237_SENSOR
start = millis();
updateTSL237();
sensor_read.tsl237_read = millis() - start;
#endif //USE_TSL237_SENSOR
#ifdef USE_TSL2591_SENSOR
start = millis();
updateTSL2591();
sensor_read.tsl2591_read = millis() - start;
#endif //USE_TSL2591_SENSOR
Send current sensor data as JSON document to Serial
String getSensorData(bool pretty) {
const int docSize = JSON_OBJECT_SIZE(6) + // max 6 sensors
JSON_OBJECT_SIZE(1) + // token data
JSON_OBJECT_SIZE(4) + // BME280 sensor
JSON_OBJECT_SIZE(3) + // DHT sensors
JSON_OBJECT_SIZE(3) + // MLX90614 sensor
JSON_OBJECT_SIZE(3) + // TSL237 sensor
JSON_OBJECT_SIZE(7) + // TSL2591 sensor
JSON_OBJECT_SIZE(6); // Davis Anemometer
StaticJsonDocument < docSize > weatherDoc;
serializeAnemometer(weatherDoc);
serializeBME(weatherDoc);
serializeDHT(weatherDoc);
serializeMLX(weatherDoc);
serializeTSL237(weatherDoc);
serializeTSL2591(weatherDoc);
String result = "";
if (pretty)
serializeJsonPretty(weatherDoc, result);
serializeJson(weatherDoc, result);
return result;
String getCurrentVersion() {
StaticJsonDocument <JSON_OBJECT_SIZE(1)> doc;
doc["version"] = METEORADIO_VERSION;
String result = "";
serializeJson(doc, result);
return result;
String getReadDurations() {
StaticJsonDocument <JSON_OBJECT_SIZE(6)> doc;
if (bmeData.status) doc["BME"] = sensor_read.bme_read;
if (dhtData.status) doc["DHT"] = sensor_read.dht_read;
if (mlxData.status) doc["MLX90614"] = sensor_read.mlx90614_read;
if (tsl237Data.status) doc["TSL237"] = sensor_read.tsl237_read;
if (tsl2591Data.status) doc["TSL2591"] = sensor_read.tsl2591_read;
if (anemometerData.status) doc["Davis Anemometer"] = sensor_read.davis_read;
String result = "";
return result;
// translate the sensor configurations to a JSON document
String getCurrentConfig() {
const int docSize = JSON_OBJECT_SIZE(4) + // max 4 configurations
JSON_OBJECT_SIZE(2) + // DHT sensors
JSON_OBJECT_SIZE(3) + // Davis Anemometer
JSON_OBJECT_SIZE(3) + // WiFi parameters
JSON_OBJECT_SIZE(1) + // Arduino
JSON_OBJECT_SIZE(2); // buffer
StaticJsonDocument <docSize> doc;
#ifdef USE_WIFI
// currently, we have memory info only available for ESP8266
JsonObject arduinodata = doc.createNestedObject("Arduino");
arduinodata["free memory"] = freeMemory();
#endif
JsonObject dhtdata = doc.createNestedObject("DHT");
dhtdata["pin"] = DHTPIN;
dhtdata["type"] = DHTTYPE;
#endif
JsonObject davisdata = doc.createNestedObject("Davis Anemometer");
davisdata["wind speed pin"] = ANEMOMETER_WINDSPEEDPIN;
davisdata["wind direction pin"] = ANEMOMETER_WINDDIRECTIONPIN;
davisdata["wind direction offset"] = ANEMOMETER_WINDOFFSET;
#endif
#ifdef USE_WIFI
JsonObject wifidata = doc.createNestedObject("WiFi");
wifidata["SSID"] = esp8266Data.ssid;
wifidata["connected"] = WiFi.status() == WL_CONNECTED;
if (WiFi.status() == WL_CONNECTED)
wifidata["IP"] = WiFi.localIP().toString();
wifidata["IP"] = "";
#endif
String result = "";
if (doc.isNull())
return "{}";
else {
return result;
unsigned long lastSensorRead;
Serial.begin(BAUD_RATE);
// wait for serial port to connect. Needed for native USB
while (!Serial) continue;
// sensors never read
lastSensorRead = 0;
initAnemometer();
initTSL237();
#ifdef USE_WIFI
initWiFi();
if (WiFi.status() == WL_CONNECTED) {
server.on("/", []() {
server.send(200, "application/json; charset=utf-8", getSensorData(false));
server.on("/w", []() {
server.on("/p", []() {
server.send(200, "application/json; charset=utf-8", getSensorData(true));
server.on("/c", []() {
server.send(200, "application/json; charset=utf-8", getCurrentConfig());
server.on("/v", []() {
server.send(200, "application/json; charset=utf-8", getCurrentVersion());
server.on("/r", []() {
reset();
server.on("/t", []() {
server.send(200, "application/json; charset=utf-8", getReadDurations());
server.onNotFound([]() {
server.send(404, "text/plain", "Ressource not found: " + server.uri());
server.begin();
#endif
// initial readout all sensors
updateSensorData();
String input = "";
void parseInput() {
// ignore empty input
if (input.length() == 0)
return;
switch (input.charAt(0)) {
case 'v':
Serial.println(getCurrentVersion());
case 'w':
Serial.println(getSensorData(false));
case 'c':
Serial.println(getCurrentConfig());
case 'p':
Serial.println(getSensorData(true));
case 't':
Serial.println(getReadDurations());
#ifdef USE_WIFI
case 's':
if (input.length() > 2 && input.charAt(1) == '?')
parseCredentials(input.substring(2));
disconnectWiFi();
initWiFi();
case 'd':
disconnectWiFi();
case 'r':
reset();
#endif
Command loop handling incoming requests and returns a JSON document.
'v' - send current version
'w' - send current weather sensor values
'p' - send current weather sensor values (pretty printed)
't' - send sensor read durations
'c' - send sensor configuration settings
byte ch;
String valStr;
int val;
#ifdef USE_WIFI
wifiServerLoop();
#endif
updateTSL237();
updateAnemometer();
if (Serial.available() > 0) {
ch = Serial.read();
if (ch == '\r' || ch == '\n') { // Command received and ready.
parseInput();
input = "";
input += (char)ch;
// regularly update sensor data
unsigned long now = millis();
if (abs(now - lastSensorRead) > MAX_CACHE_AGE) {
updateSensorData();
lastSensorRead = now;
delay(50);
Du coup voila , ci qqun a une idée .......
Merci et bientot
Chrsitophe
