Problems at the time of reading a rfid card
Hi, I'm doing a project access control, and I have to implement in real life.
The system works as follows:
If the reader detects a new card in the system verifies whether or not, if there opens the door, otherwise no.
The user has a menu, which can save a tag in the system.
Problem:
My only problem is when saving a new label, the reader does not detect if a new card and when he does detect a new card the reader does not leave the condition, while the Arduino itself.
And as a result to bring a different card (to access the site) stored in the EEPROM memory, (and not open the door).
#include <SPI.h>
#include <MFRC522.h>
#include <EEPROM.h>
#include <Keypad.h>
#include <LiquidCrystal.h>
#define SS_PIN 53
#define RST_PIN 9
MFRC522 rfid(SS_PIN, RST_PIN);   // Configura los pines RST y SS del mrfc522
MFRC522::MIFARE_Key key;
///////////////////////LCD///////////////////////////////////////
//Incializa la libreria con los numeros de pines a interactuar el LCD
LiquidCrystal lcd(A8, A9, A10, A11, A12, A13);
//////////////Teclado/////////////////////////////////////////////
//Definición de filas y columnas
const byte Filas = 4; //Cuatro filas
const byte Cols = 4; //Cuatro columnas
//Definición de los pines
byte Pins_Filas[] = {37, 35, 33, 31}; //Pines Arduino para las filas
byte Pins_Cols[] =  {29, 27, 25, 23}; // Pines Arduino para las columnas
//Definición de las teclas
char Teclas [ Filas ][ Cols ] =
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
//Se crea una instancia llamada Teclado1 y el cual asignara las teclas que tenemos en el arreglo "Teclas" y le decimos
//que se han conectados los pines de las filas y columnas
Keypad kpd = Keypad(makeKeymap(Teclas), Pins_Filas, Pins_Cols, Filas, Cols);
char Teclado ()
  do{
   char Tecla = kpd.getKey();
    if (Tecla != NO_KEY)
      return Tecla;
  } while (1);
#define CREDENTIALSOFFSET  11
struct USERCREDENTIALS
  // space for 9 character id and terminating nul character
  char id[6];
  byte rfid[3];
} usercredential;
// array with user credentials
USERCREDENTIALS credentials[15];
char  Ingresar_ID[6];
  lcd.begin(20, 4); //Configura el LCD con el numero de columas y filas. Para un LCD 16x4: 16 columnas y 4 filas.
  lcd.display(); //Enciende el display
  SPI.begin();               // Incializa la comunicacion SPI
  rfid.PCD_Init(); // Init MFRC522
    for (byte i = 0; i < 6; i++) {
      key.keyByte[i] = 0xFF;
   //If the sensor rfid detects that there is a card verify if exists or not in the system
   leer_usuario();
   lcd.clear();
   lcd.setCursor(0,0);lcd.print("Modo lectura");   //Imprime en la LCD
   lcd.setCursor(3,3);lcd.print("Presione *");   //Imprime en la LCD
   int Tecla = kpd.getKey();
    if(Tecla == '*'){  //Pressing asterisk access main menu
   lcd.clear();
   lcd.setCursor(0,0);lcd.print("Menu");   //Imprime en la LCD
   lcd.setCursor(0,1);lcd.print("1. Add user");   //Imprime en la LCD
   lcd.setCursor(0,2);lcd.print("2. Menu 2");   //Imprime en la LCD
    kp = Teclado ();
   switch (kp){
    case '1':
            guardar_tag();
    case '2':
     lcd.clear();
//THIS CONDITION WORKS VERY WELL BECAUSE IT CARRIES THE 'RETURN'
bool leer_usuario(){
   // Look for new cards
  if ( ! rfid.PICC_IsNewCardPresent())
    return false;
  // Verify if the NUID has been readed
  if ( ! rfid.PICC_ReadCardSerial())
    return false;
   for(int user=0; user < sizeof(credentials) / sizeof(USERCREDENTIALS); user ++){ //cambiar por credential, usarios credenciales
            if ((rfid.uid.uidByte[0] == credentials[user].rfid[0]) && (rfid.uid.uidByte[1] == credentials[user].rfid[1]) && (rfid.uid.uidByte[2] == credentials[user].rfid[2]) && (rfid.uid.uidByte[3] == credentials[user].rfid[3])) {
                    lcd.clear ();
                    lcd.setCursor(0,0); lcd.print("Open door");
                    lcd.clear ();
                else{
                     if(user == (sizeof(credentials) / sizeof(USERCREDENTIALS)-1)){
                       lcd.clear ();
                       lcd.setCursor(0,0); lcd.print("tag does not exist");
                       lcd.clear ();
      // Terminamos la lectura de la tarjeta  actual
           rfid.PICC_HaltA();
          // Stop encryption on PCD
          rfid.PCD_StopCrypto1();
bool guardar_tag(){
  //Enter the user id
 lcd.clear();  //Limpia pantalla
 lcd.setCursor(3,0); lcd.print("Enter user ID"); //Imprime en la lcd
for(i=0; i<sizeof(Ingresar_ID); i++){ //Sizeof obtiene el tamaño del arreglo Ingresar_ID, con el fin de obtener un valor exacto y facilite al programador si decea cambiar el tamaño del arreglo, no cambiarlo el tamaño en todos las funciones que se utilizaron con dicho arreglo.
    kp = Teclado (); //Obtiene el valor de la tecla pulsada
    Ingresar_ID[i]=kp; //Guardar la tecla pulsada en el arreglo
    if(i<5){
      lcd.setCursor(5+i,3); lcd.print(Ingresar_ID[i]); //Imprime en la lcd
    if(Ingresar_ID[i] == 'A'){ //Si presiona A compara si el ID existe o no
        Ingresar_ID[i] = '\0'; //Sustituir por el caracter nul
        break; //Se sale del ciclo y ejecuta la funcion de comparacion del ID
  if ((Ingresar_ID[1] == '\0') || (Ingresar_ID[2] == '\0') || (Ingresar_ID[3] == '\0') || (Ingresar_ID[4] == '\0') || (Ingresar_ID[5] == '\0')){
            if(strcmp (credentials[user].id, Ingresar_ID)==0){ //If you found the id
              lcd.clear();//Limpia Pantalla
              lcd.setCursor(2,0);lcd.print("putting the tag");  //Imprime en la LCD
              delay(5000);
              //Check if there is a new card
              if ( ! rfid.PICC_IsNewCardPresent()){
                   //Check if the ID has been read
                   if ( ! rfid.PICC_ReadCardSerial()){
                        for (byte j = 0; j < 4; j++) {
                             credenciales[user].rfid[j] = rfid.uid.uidByte[j]; //save
                        //saved in eeprom memory
                      for (i = 0; i < sizeof(credentials) / sizeof(USERCREDENTIALS); i++){
                          EEPROM.put(i * sizeof(USERCREDENTIALS)+ CREDENTIALSOFFSET, credentials[i]);
                       lcd.clear ();
                       lcd.setCursor(5,1); lcd.print("save");
                       lcd.clear();
                         rfid.PICC_HaltA();
                  // Detiene la  encryptacion on PCD
I am having problems with the condition "guardar_tag ()", so the reader detects a new card should of carry "return"
I them remove because at the time of put you "return" not me allows enter to the condition
       //return;
      //return;
I am sure that much of the problem is that, but at the time of put "return" does not execute the following condition.
By please help
(translated by google)
From what? Perhaps you should be posting in your native language.
The return statement means go back to the caller. Of course no code after the return statement is executed.
You MUST make the function WAIT until a tag is presented. There is NO other way.
