Hi all,
I am trying to integrate the MKR GPS shield (on I2C) and Air Quality Monitor (on Serial1) together on an MKR 1400. Using examples provided for each, both execute fine when run separately. However when I try and run the two in the same sketch, i don't have any GPS data coming through (only the Serial1 data is printed). Is anyone aware of a known issue with MKR GPS shield and a separate serial input, or am i missing something basic in my syntax? I've spent a while trying to figure it out, but cant find a solution.
With regard to wiring:
VCC--5v
GND--GND
Tx--Rx (pin 13 on MKR 1400)
Rx--Tx (pin 14 on MKR 1400)
RST--RESET
MKR GPS shield is connected directly into I2C on the MKR 1400
Below is my full code:
#include <Arduino_MKRGPS.h>
char col;
unsigned int PMSa = 0,FMHDSa = 0,TPSa = 0,HDSa = 0,PMSb = 0,FMHDSb = 0,TPSb = 0,HDSb = 0;
unsigned int PMS = 0,FMHDS = 0,TPS = 0,HDS = 0,CR1 = 0,CR2 = 0;
unsigned char buffer_RTT[40]={}; //Serial buffer; Received Data
char tempStr[15];
// initialize serial communications and wait for port to open:
Serial.begin(112500);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial1.begin(9600);
// If you are using the MKR GPS as shield, change the next line to pass
// the GPS_MODE_SHIELD parameter to the GPS.begin(...)
if (!GPS.begin()) {
Serial.println("Failed to initialize GPS!");
while (1);
// check if there is new GPS data available
if (GPS.available()) {
// read GPS values
float latitude = GPS.latitude();
float longitude = GPS.longitude();
float altitude = GPS.altitude();
float speed = GPS.speed();
int satellites = GPS.satellites();
// print GPS values
Serial.print("Location: ");
Serial.print(latitude, 7);
Serial.print(", ");
Serial.println(longitude, 7);
Serial.print("Altitude: ");
Serial.print(altitude);
Serial.println("m");
Serial.print("Ground speed: ");
Serial.print(speed);
Serial.println(" km/h");
Serial.print("Number of satellites: ");
Serial.println(satellites);
while(!Serial1.available());
while(Serial1.available()>0) //Data check: weather there is any Data in Serial1
for(int i=0;i<40;i++)
col =Serial1.read();
buffer_RTT[i]=(char)col;
delay(2);
Serial1.flush();
CR1 =(buffer_RTT[38]<<8) + buffer_RTT[39];
CR2 = 0;
for(int i=0;i<38;i++)
CR2 += buffer_RTT[i];
if(CR1 == CR2) //Check
PMSa=buffer_RTT[12]; //Read PM2.5 High 8-bit
PMSb=buffer_RTT[13]; //Read PM2.5 Low 8-bit
PMS=(PMSa<<8)+PMSb; //PM2.5 value
FMHDSa=buffer_RTT[28]; //Read Formaldehyde High 8-bit
FMHDSb=buffer_RTT[29]; //Read Formaldehyde Low 8-bit
FMHDS=(FMHDSa<<8)+FMHDSb; //Formaldehyde value
TPSa=buffer_RTT[30]; //Read Temperature High 8-bit
TPSb=buffer_RTT[31]; //Read Temperature Low 8-bit
TPS=(TPSa<<8)+TPSb; //Temperature value
HDSa=buffer_RTT[32]; //Read Humidity High 8-bit
HDSb=buffer_RTT[33]; //Read Humidity Low 8-bit
HDS=(HDSa<<8)+HDSb; //Humidity value
PMS = 0;
FMHDS = 0;
TPS = 0;
HDS = 0;
Serial.println("-----------------------uart--------------------------");
Serial.print("Temp : ");
sprintf(tempStr,"%d%d.%d",TPS/100,(TPS/10)%10,TPS%10);
Serial.print(tempStr);
Serial.println("C"); //Serial pring Temperature
Serial.print("RH : ");
sprintf(tempStr,"%d%d.%d",HDS/100,(HDS/10)%10,HDS%10);
Serial.print(tempStr); //Serial print humidity
Serial.println(" %"); //"%"
Serial.print("HCHO : ");
Serial.print(FMHDS);
Serial.println(" ug/m3"); // Serial print formaldehyde, unit: ug/m³
Serial.print("PM2.5: ");
Serial.print(PMS);
Serial.println(" ug/m3"); // Serial print PM2.5, unit: ug/m³
