problems receiving mqtt message
I have a problem: I am receiving a .json message from Firebase through Node-red and send it via mqtt to ESP32. I can receive the message when something is changed in Firebase due to the callback function of the "ArduinoMqttClient" library, but I would like to get the data as soon as I load the sketch in ESP32.
Currently, when I upload the sketch, the topic is signed but I only get the message if I change something in Firebase.
I don't have much experience with mqtt, I don't know if I can get the message of the topic when loading the program to the ESP32.
Here is the complete code and attached (for curiosity) the flow in node-red:
#include <ArduinoMqttClient.h>
#include <WiFi.h>
#include <ArduinoJson.h>
char ssid[] = "wifi";
char pass[] = "password123";
WiFiClient wifiClient;
MqttClient mqttClient(wifiClient);
const String ORG = "abcde";
const String DEVICE_TYPE = "ESP32";
const String DEVICE_ID = "008";
#define DEVICE_TOKEN "SD78963214!@#$"
const String CLIENT_ID = "d:" + ORG + ":" + DEVICE_TYPE + ":" + DEVICE_ID;
const char broker[] = "abcde.messaging.internetofthings.ibmcloud.com";
int        port     = 1883;
const char topic[]  = "iot-2/cmd/firebaseData/fmt/json";
String json;
  while (WiFi.begin(ssid, pass) != WL_CONNECTED) {
    Serial.print(".");
    delay(5000);
  mqttClient.setId(CLIENT_ID);
  mqttClient.setUsernamePassword("use-token-auth", DEVICE_TOKEN);
  if (!mqttClient.connect(broker, port)) {
    Serial.println(mqttClient.connectError());
    while (1);
  mqttClient.onMessage(onMqttMessage);
  mqttClient.subscribe(topic);
  mqttClient.messageTopic();
  while (mqttClient.available()) {
    char j = mqttClient.read();
    json += j;
  Serial.println("JSON: ");
  Serial.println(json);
  mqttClient.poll();
void onMqttMessage(int messageSize)
  json = "";
  Serial.print(mqttClient.messageTopic());
  Serial.print("', length ");
  Serial.print(messageSize);
  Serial.println(" bytes:");
    json += j;
  Serial.println("JSON");
Thank you!
Take a look at MQTT retained messages.
Thank you, @wildbill!
The publisher needs to post the message to the topic with a retention flag as true, right?
So, every new subscriber is able to receive the last valid message.
got it right?
I believe so - not that I've ever used that feature.
HiveMQ has a very good description of retained messages. (Watch the video).
Thank you @wildbill and @SteveMann !
It works! :)
