Problems with a Dnd Dice roller- it rolls... all the dice?
Hey yall- first time posting here. I'm working on a small project that is a dnd dice roller with two buttons- One to select the dice and one to roll it. Not i'm pretty new to arduino programming so theres likely a simple solution to this- but i'll start by explaining the issue.
I can press the button to navigate from one menu to another, but when i go to roll the dice in that menu, it rolls something random.
My setup and init look like this:
(forgive my shitty commenting)
// libraries
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <TrueRandom.h>
//variables
#define menu 3
// menu size
const int menuSize = 7;
String menuItems[menuSize];
int currMenu = 0;
String temp;
bool Next = HIGH;
char currentPrintOut[10];
Adafruit_SSD1306 display(4);
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // setup the OLED
  pinMode(2, INPUT); // setup button 3
  pinMode(3, INPUT_PULLUP); // setup button 2
  display.clearDisplay();
  display.setTextColor(WHITE);
  display.setTextSize(2);
  display.drawRect(0, 0, 128, 8, WHITE);
  display.display(); // write to display
// the one array
  menuItems[0] = "D2";
  menuItems[1] = "D4";
  menuItems[2] = "D6";
  menuItems[3] = "D8";
  menuItems[4] = "D10";
  menuItems[5] = "D12";
  menuItems[6] = "D20";
  MenuChanged();
The function it calls at the end is:
void MenuChanged() {
  if (currMenu < 4) {
    display.setCursor(53, 15);
  else {
    display.setCursor(48, 15);
  temp = String (menuItems[currMenu]);
  temp.toCharArray (currentPrintOut, 10);
  display.println(currentPrintOut); // write the roll
  Serial.println(currentPrintOut); // write the roll
  delay(100);
So here is where I think its breaking- ALSO i realize there is likely an easier way to frite this, but i'm new so a bunch of if statements is what i had for now.
Main loop(likely broken):
  if (digitalRead(3) != Next) {
    Next = !Next;
    if (!Next) {
      //pressed
      if (currMenu > 0) {
        currMenu--;
      else {
        currMenu = menuSize - 1;
      MenuChanged();
      Serial.print (currMenu);
  if (digitalRead(2) == HIGH) {
    delay(15);
      if (currMenu = 0) {
        d2Roll();
    delay(15);
      if (currMenu = 1) {
        d4Roll();
    delay(15);
      if (currMenu = 2) {
        d6Roll();
    delay(15);
      if (currMenu = 3) {
        d8Roll();
    delay(15);
      if (currMenu = 4) {
        d10Roll();
    delay(15);
      if (currMenu = 5) {
        d12Roll();
    delay(15);
      if (currMenu = 6) {
        d20Roll();
I know this looks like a lot, but basically after i check if a button is pressed, the same if statement repeats itsself:
    delay(15);
      if (currMenu = 6) {
        d20Roll();
it just changes per dice.
Speaking of the logic behind rolling the dice looks like this:
void d20Roll() {
  display.fillScreen(BLACK); // erase all
  display.setCursor(0, 0);
  int roll = TrueRandom.random(1, 21); // store the number
  if (roll == 20) {
    drawStar();
    display.setCursor(77, 14);
    display.println("20"); // daaamn yuss
  else if (roll == 1) {
    display.setCursor(87, 14);
    display.println("1"); //get rekt
    drawSkull();
  else if (roll < 10) {
    // single character number
    d20(); // draw the outline
    display.setTextColor(BLACK);
    display.setCursor(60, 15);
    display.println(roll); // write the roll
  else {
    // dual character number
    display.setCursor(52, 15);
  delay(100);
The problem is in my mind- while not perfect, the dice should roll ok- ish. But somethign is terribly wrong...
I've appended the full code is anyone wants it here
if (currMenu = 6)
etc.
You meant ==
Hold on in bed must get up and check
pcbbc:
if (currMenu = 6)
etc.
You meant ==
YOU WERE RIGHT
Thank you! I come from totally different coding languages to these things get a bit lost on me sometimes!!
