I want to combine a piezo speaker with a push button, so when you push the button, you can hear a song coming from the piezo speaker (one time). I have a code, but there’s something not right, because it’s not working. Any advise?
int speakerPin = 2;
int inPin = 4; // choose the input pin (for a pushbutton)
int val = 0; // variable for reading the pin status
boolean isPushed = false; // variable for the status of the button
boolean isPressed = false; // variable for the status of the piezo
boolean oncePressed = false;
int length = 15; // the number of notes
char notes[] = "ccggaagffeeddc "; // a space represents a rest
int beats[] = { 1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 4 };
int tempo = 300;
pinMode(speakerPin, OUTPUT);
pinMode(inPin, INPUT); // declare pushbutton as input
Serial.begin(9600); // set up the pathway to write on your monitor
void playTone(int tone, int duration) {
for (long i = 0; i < duration * 1000L; i += tone * 2) {
digitalWrite(speakerPin, HIGH);
delayMicroseconds(tone);
digitalWrite(speakerPin, LOW);
void playNote(char note, int duration) {
char names[] = { 'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C' };
int tones[] = { 1915, 1700, 1519, 1432, 1275, 1136, 1014, 956 };
// play the tone corresponding to the note name
for (int i = 0; i < 8; i++) {
if (names[i] == note) {
playTone(tones[i], duration);
void loop(){
val = digitalRead(inPin); // read input value
Serial.println(val); // print the value of "value" on the Serial Monitor
if (val == HIGH) { // check if the input is HIGH (button pushed)
oncePressed = true;
isPushed = true;
if(isPushed){
if(isPressed){
digitalWrite(speakerPin, LOW); // turn music OFF
stopMuziek();
isPressed = false;
} else{
if(oncePressed){
digitalWrite(speakerPin, HIGH); // turn music ON
speelMuziek();
isPressed = true;
isPushed = false;
void stopMuziek(){
noTone(5);
void speelMuziek(){
for (int i = 0; i < length; i++) {
if (notes[i] == ' ') {
delay(beats[i] * tempo); // rest
playNote(notes[i], beats[i] * tempo);
// pause between notes
delay(tempo / 2);
stopMuziek();
