Problems with making multi cpp file (platformio)
I am trying to learn to split my cpp code to make it easier to read so i tried to make just measuring temperature with themistors for beggining.
I made a header file named temp_calc.h
#pragma once
#ifndef __TEMP_CALC__
#define __TEMP_CALC__
#define Thermistor_Pin A1 // pin that's connected to thermistor1
#define R1 470
float logR2, R2, c1 = 1.009249522e-03, c2 = 2.378405444e-04, c3 = 2.019202697e-07; // constants for calculating temperature
double Temperature = 0;
const int numReadings = 16;
int ThermistorValue = 0, ThermistorValue1 = 0, ThermistorValue2 = 0;
int readingsHeatblockTemperature[numReadings], readIndex = 0;
long total = 0, average = 0;
double Calculate_Temperature(int Thermistor_Pin);
#endif
temp_calc.cpp
#include "Arduino.h"
#include "temp_calc.h"
    for (int i = 0; i < numReadings; i++)
        total = total - readingsHeatblockTemperature[readIndex];
        readingsHeatblockTemperature[readIndex] = analogRead(Thermistor_Pin);
        total = total + readingsHeatblockTemperature[readIndex];
        readIndex = readIndex + 1;
        if (readIndex >= numReadings)
            readIndex = 0;
        average = total / numReadings;
        ThermistorValue = average;
        R2 = R1 * ((1023.0 / ThermistorValue) - 1.0);
        logR2 = log(R2);                                                      // math shit
        Temperature = (1.0 / (c1 + c2 * logR2 + c3 * logR2 * logR2 * logR2)); // temperature in kelvins
        Temperature = Temperature - 273.15;                                   // temperature in celsius
        // HeatblockTemperature = (HeatblockTemperature * 9.0) / 5.0 + 32.0;              // temperature in fanrenheit
    return Temperature;
and in the main cpp file i just call the function with
HeatblockTemperature1 = Calculate_Temperature(Thermistor1Pin); HeatblockTemperature2 = Calculate_Temperature(Thermistor2Pin);
I have heatblockTemperature variables defined in the main cpp, i get errors that there are duplicates/multiple definitons of variables, is this because i named the header and the cpp file that holds the function the same name?
I always start local Variables with an underscore e.g. _MyVar
Only global variable declarations belong in the .h file (using 'extern'), NEVER variable definitions. See the difference here:
Also, here are additional guidelines:
Has nothing to do with OP's problem.
Ok i took a look at these links and other resources and i get it a bit more now, i got it to compile,
temp_calc.cpp
#define Thermistor2Pin A0 // pin that's connected to thermistor2
#define R1 470
const int numReadings = 32;
void Calculate_Temperature(int Thermistor_Pin, double Temperature)
            readIndex = 0;
temp_calc.h
pragma once
#ifndef __TEMP_H
#define __TEMP_H
extern void Calculate_Temperature(int Thermistor_Pin, double Temperature);
#endif
And in the main cpp i defined a global variable for thermistor pin and i called the function in loop.
Calculate_Temperature(Thermistor1Pin,
HeatblockTemperature);
It compiled but haven't tested yet if it really works, i have some more questions, i usually define pin names with #define, but i don't know how to put define in function as a parameter?
And if i put void before function that tells the compiler the function won't return any values, would it be better if i put double before function and make it return value, i'm not sure how it's done correctly?
