I was experimenting with a multitasking library (cth from CopyThreads), when I got a mystic behavior of the program - a static int variable would not work ???
I use IDE version 1.8.10, and run it on an Uno.
I tried to quit the library, but I still get the same behavior, with the following relatively simple code:
// Output
int grnPin = 3; // Green LED, connected to digital pin 3
int yelPin = 4; // Yellow LED, connected to digital pin 4
int redPin = 5; // Red LED, connected to digital pin 5
int kontLED = 6; // LED for indicationg LED state
int kontakt = 8; // Contact input from switch
pinMode(redPin, OUTPUT); // sets the pins as output
pinMode(grnPin, OUTPUT);
pinMode(yelPin, OUTPUT);
Serial.begin(9600); // ...set up the serial ouput
boolean redState = false;
boolean grnState = false;
boolean yelState = false;
blinkRed();
blinkGrn();
blinkYel();
unsigned long nextTimeRed = 0;
unsigned long nextTimeGrn = 0;
unsigned long nextTimeYel = 0;
void blinkRed(void)
static int val = analogRead(A0);
val = map(val, 0, 1023, 100, 1000);
if (millis() - nextTimeRed >= val) {
nextTimeRed += val;
digitalWrite(redPin, redState);
redState = ! redState;
Serial.print(val);
Serial.println(" Red");
void blinkGrn(void)
if (millis() - nextTimeGrn >= 2000) {
nextTimeGrn += 2000;
digitalWrite(grnPin, grnState);
grnState = ! grnState;
Serial.print(millis());
Serial.println(" Grn");
void blinkYel(void)
if (millis() - nextTimeYel >= 500) {
nextTimeYel += 500;
digitalWrite(yelPin, yelState);
yelState = ! yelState;
Serial.println(" Yel");
The variable that fails is at line 33, and converted with map() it is stuck at 824, and not changeing although the input at A0 changes.
If I change the code to use a simple local variable it works.
If I move the variable out as a global variable it works.
I am confused
