Problems with Stepper Motor + Pololu a4998
Good afternoon,
I have made all the connections following the scheme at the webpage of Pololu but my stepper motor does not respond. It is a NEMA 17 4V 1.8°/step. My purpose is rotating the motor in one single direction a number of steps.
This is the code I am using:
#define STEP_PIN 2
int numberOfSteps = 100;
digitalWrite(STEP_PIN, LOW);
pinMode(STEP_PIN, OUTPUT);
for(int i = 0; i < numberOfSteps; i++)
digitalWrite(STEP_PIN, HIGH);
delay(250);
delay(250);
while(1);
Following the instructions of Pololu I have connected the pin DIR to the GND of Arduino, even if I am not interested in using it, the voltage can fluctuate if I leave it without connection.
Apart from this I have tried another code. The motor responds but it does not do what it is written in the code.
Here is the second code:
#include <Stepper.h> //Importamos la librería para controlar motores paso a paso
#define STEPS 200 //Ponemos el número de pasos que necesita para dar una vuelta. 200 en nuestro caso
// Ponemos nombre al motor, el número de pasos y los pins de control
Stepper stepper(STEPS, 2, 3); //Stepper nombre motor (número de pasos por vuelta, pins de control)
// Velocidad del motor en RPM
stepper.setSpeed(100);
//Girar una vuelta entera en un sentido
stepper.step(200);
delay(500); //Pequeña pausa
//Girar una vuelta entera en sentido contrario
stepper.step(-200);
What can be the problem. You have any suggestions to modify the code, in particular the first one?
Thank you
Can you please post a copy of your sketch, using code tags?
They are made with the </> icon in the reply Menu.
See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
This will give your sketch its own scroll-able window.
Tom.... :slight_smile:
Please post a link to the datasheet for your stepper motor.
You should do pinMode() before digitalWrite()
Have a look at stepper motor basics and this simple stepper code
...R
Its probably setup for microsteps, doing 2 microsteps per second is very slow, change those
delays to 5 ms perhaps?
Hello,
Sorry for the code. I post it again.
#define STEP_PIN 2
  {  // Opening brace
    delay(250);
    delay(250);
  }  // Closing brace
  while(1);
I have put before the pinmode and change the delay value but still does not work... my motor is bipolar, 1.2 A/phase and 4V.
Regarding the second code it works now. I post it:
Stepper stepper(STEPS, 8, 9); //Stepper nombre motor (número de pasos por vuelta, pins de control)
  stepper.step(200);
If I use the second one I would be interested in stoping the motor once it has rotated the steps I want. Is it possible to do it directly from the code or is it neccesary to place a button on the breadboard? If so could you please tell me how should I modify the second code and how to do the connection of the button?
Thanks for your time
victorhernaiz:
I don't understand.
Your code contains
stepper.step(200);
Doesn't that stop after 200 steps ?
I presume 200 is the number of steps you want ?
...R
Yes exactly. It makes one turn but after the delay that is set it starts making another turn, and then another...as the function it is inside the loop.
I would like to stop it. That is why I was asking you about incorporating a button or if you know how to do it directly from the code.
Thanks
victorhernaiz:
Thanks
Then you need a variable to record the state of your system - perhaps motorHasMoved and code like this
if (motorHasMoved == false) {
    stepper.step(200);
    motorHasMoved = true;
...R
