Problems with "string" variables
Hello,
I have problems with "string" variables.
I want to write a text on a string variable in my code.
The problem is that the text is reset with every new beginning of the "void loop".
I think that I have a mistake in thinking.
I would be very happy about answers!
Many Thanks!!!
Here is some example code:
String mystring = "Hello";
  Serial.println(mystring); // first run:"Hello"; second pass, ALSO:"Hello"
  String mystring = "world";
  Serial.println(mystring); // first run:"world"; second pass:"world"
  delay(200);
I want both to have variables "world" on the second run.
Suppose that loop() has executed 3 times. What do you want printed ?
Read about variable scope
You have two mystring variables, a global and a local one
I want the following to be output.
Hello
world
world
world
world
world
did you read the link about "scope" ?
do you understand why your code is wrong?
Thanks for your answer. I looked at the link. But not not understood.
can you explain to me why the string is being reset. and what can I do about it?
Thanks for your answer!
when you do
you declare and define a GLOBAL variable named mystring, initialized with the content Hello
This variable's lifetime is the one of the whole program as it's a global variable and it's visible everywhere (read scope, practice )
when you do this in the loop
you declare and define the LOCAL variable named ASLO mystring initialized with the content world
this LOCAL variable - from there on - in the loop() function will hide the GLOBAL variable of the same name (which content has not changed, it's still Hello)
so
  Serial.println(mystring); // ==> PRINT THE GLOBAL VARIABLE
  Serial.println(mystring); //  ==> PRINT THE LOCAL VARIABLE
if you don't want the local variable, don't re-declare a variable... just assign the new value (don't declare!)
  Serial.println(mystring);  // ==> FIRST RUN WILL PRINT THE INITIAL VALUE OF THE GLOBAL VARIABLE
  mystring = "world";        // ==> ASSIGN A NEW VALUE TO THE GLOBAL VARIABLE
  Serial.println(mystring);  // PRINT THE MODIFIED CONTENT
  delay(200);
change
to
mystring = "world";
Many thanks for your help !
Thank you "J-M-L" for your explanation. I understand it. Thank you so much!
Thank you "killzone_kid" your idea worked.
Thank-you!
If you are using Arduino Strings check out my tutorial on
Taming Arduino Strings
