Hi its my first Arduino project and i´m having problems using a code which is using the FastLED library.
When I´m using examples From the Adafruit NeoPixel library the WS2812B led strip is working just perfect.
If I use the FastLed Library everything is just flashing in the wrong colors and is blinking all the time.
I don´t even know if it´s possible but could anyone change this code so its using the Adafruit neopixel library?
Thanks in advance ![]()
This is the project I´m trying to get to work:
Lighting Cloud Mood Lamp By James Bruce
View the full tutorial and build guide at http://www.makeuseof.com/
Sound sampling code originally by Adafruit Industries. Distributed under the BSD license.
This paragraph must be included in any redistribution.
#include <Wire.h>
#include "FastLED.h"
// How many leds in your strip?
#define NUM_LEDS 300
#define DATA_PIN 2
// Mode enumeration - if you want to add additional party or colour modes, add them here; you'll need to map some IR codes to them later;
// and add the modes into the main switch loop
enum Mode { CLOUD, ACID, OFF, ON, RED, GREEN, BLUE, FADE};
Mode mode = FADE;
Mode lastMode = CLOUD;
// Mic settings, shouldn't need to adjust these.
#define MIC_PIN 0 // Microphone is attached to this analog pin
#define DC_OFFSET 0 // DC offset in mic signal - if unusure, leave 0
#define NOISE 10 // Noise/hum/interference in mic signal
#define SAMPLES 10 // Length of buffer for dynamic level adjustment
byte
volCount = 0; // Frame counter for storing past volume data
int
vol[SAMPLES]; // Collection of prior volume samples
int n, total = 30;
float average = 0;
// used to make basic mood lamp colour fading feature
int fade_h;
int fade_direction = -1;
// Define the array of leds
CRGB leds[NUM_LEDS];
// this line sets the LED strip type - refer fastLED documeantion for more details GitHub - FastLED/FastLED: The FastLED library for colored LED animation on Arduino. Please direct questions/requests for help to the FastLED Reddit community: http://fastled.io/r We'd like to use github "issues" just for tracking library bugs / enhancements.
FastLED.addLeds<WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS);
// starts the audio samples array at volume 15.
memset(vol, 15, sizeof(vol));
Wire.begin(9); // Start I2C Bus as a Slave (Device Number 9)
Wire.onReceive(receiveEvent); // register event
void receiveEvent(int bytes) {
// Here, we set the mode based on the IR signal received. Check the debug log when you press a button on your remote, and
// add the hex code here (you need 0x prior to each command to indicate it's a hex value)
while (Wire.available())
unsigned int received = Wire.read();
Serial.print("Receiving IR hex: ");
Serial.println(received, HEX);
lastMode = mode;
switch (received) {
case 0x4F:
mode = ON; break;
case 0x07:
mode = OFF; break;
case 0x57:
mode = CLOUD; break;
case 0xFF:
mode = ACID; break;
case 0xA7:
mode = FADE; break;
case 0x77:
mode = BLUE; break;
case 0x27:
mode = GREEN; break;
case 0x67:
mode = RED; break;
// Maps mode names to code functions.
switch (mode) {
case CLOUD: detect_thunder(); reset(); break;
case ACID: acid_cloud(); reset(); break;
case OFF: reset(); break;
case ON: constant_lightning(); reset(); break;
case RED: single_colour(0); break;
case BLUE: single_colour(160); break;
case GREEN: single_colour(96); break;
case FADE: colour_fade(); break;
default: detect_thunder(); reset(); break;
// Makes all the LEDs a single colour, see https://raw.githubusercontent.com/FastLED/FastLED/gh-pages/images/HSV-rainbow-with-desc.jpg for H values
void single_colour(int H) {
for (int i = 0; i < NUM_LEDS; i++) {
leds = CHSV( H, 255, 255);
- //avoid flickr which occurs when FastLED.show() is called - only call if the colour changes*
- if (lastMode != mode) {*
- FastLED.show();*
- lastMode = mode;*
- delay(50);*
void colour_fade() { - //mood mood lamp that cycles through colours*
- for (int i = 0; i < NUM_LEDS; i++) {*
leds = CHSV( fade_h, 255, 255);
* if (fade_h > 254) {
fade_direction = -1; //reverse once we get to 254*
* else if (fade_h < 0) {
fade_direction = 1;
_ }_
fade_h += fade_direction;
_ FastLED.show();_
_ delay(100);_
_}_
void detect_thunder() {
n = analogRead(MIC_PIN); // Raw reading from mic*
* n = abs(n - 512 - DC_OFFSET); // Center on zero*
* n = (n <= NOISE) ? 0 : (n - NOISE); // Remove noise/hum*
* vol[volCount] = n; // Save sample for dynamic leveling*
* if (++volCount >= SAMPLES) volCount = 0; // Advance/rollover sample counter*
* total = 0;*
* for (int i = 0; i < SAMPLES; i++) {*
_ total += vol*;
// If you're having trouble getting the cloud to trigger, uncomment this block to output a ton of debug on current averages.
// Note that this WILL slow down the program and make it less sensitive due to lower sample rate.
* for(int t=0; t<SAMPLES; t++) {
//initial data is zero. to avoid initial burst, we ignore zero and just add the current l*
* Serial.print("Sample item ");
Serial.print(t);
Serial.print(":");
Serial.println(vol[t]);
Serial.print("total");
Serial.println(total);
Serial.print("divided by sample size of ");
Serial.println(SAMPLES);
Serial.print("average:");
Serial.println(average);
Serial.print("current:");
Serial.println(n);
average = (total / SAMPLES) + 2;
* if (n > average) {
Serial.println("TRIGGERED");
reset();
//I've programmed 3 types of lightning. Each cycle, we pick a random one.
switch (random(1, 3)) {
//switch(3){
case 1:
thunderburst();
delay(random(10, 500));
Serial.println("Thunderburst");
case 2:
rolling();
Serial.println("Rolling");
case 3:
crack();
delay(random(50, 250));
Serial.println("Crack");
// utility function to turn all the lights off.
void reset() {_
_ leds = CHSV( 0, 0, 0);
FastLED.show();
void acid_cloud() {
// a modification of the rolling lightning which adds random colour. trippy.
//iterate through every LED*
* for (int i = 0; i < NUM_LEDS; i++) {*
* if (random(0, 100) > 90) {
leds = CHSV( random(0, 255), 255, 255);
else {
leds = CHSV(0, 0, 0);
FastLED.show();
delay(random(5, 100));
reset();
void rolling() {
// a simple method where we go through every LED with 1/10 chance*
* // of being turned on, up to 10 times, with a random delay wbetween each time*
* for (int r = 0; r < random(2, 10); r++) {
leds = CHSV( 0, 0, 255);
else {
//dont need reset as we're blacking out other LEDs her*
FastLED.show();
reset();
void crack() {
//turn everything white briefly*
FastLED.show();
delay(random(10, 100));
reset();
void thunderburst() {
// this thunder works by lighting two random lengths*
* // of the strand from 10-20 pixels._
int rs1 = random(0, NUM_LEDS / 2);
_ int rl1 = random(10, 20);_
int rs2 = random(rs1 + rl1, NUM_LEDS);
_ int rl2 = random(10, 20);
//repeat this chosen strands a few times, adds a bit of realism*
* for (int r = 0; r < random(3, 6); r++) {
for (int i = 0; i < rl1; i++) {
leds[i + rs1] = CHSV( 0, 0, 255);
}_
if (rs2 + rl2 < NUM_LEDS) {
_ for (int i = 0; i < rl2; i++) {
leds[i + rs2] = CHSV( 0, 0, 255);
FastLED.show();
//stay illuminated for a set time*
* delay(random(10, 50));
reset();
// basically just a debug mode to show off the lightning in all its glory, no sound reactivity.
void constant_lightning() {
switch (random(1, 10)) {
case 1:
thunderburst();
case 2:
rolling();
case 3:
crack();
}*_
