Problems with tiny fat and UTFT_tinyfat
I have a 5" sainsmart TFT LCD with shield on an arudino mega 2560.
I want to display an image on the screen from the sd card. Why is there not an abundant amount of information on this? Why else would you buy this other than to use it?
I am having big times errors when compiling...
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Mega 2560 or Mega ADK"
C:\Program Files (x86)\Arduino\libraries\UTFT_tinyFAT\UTFT_tinyFAT.cpp:20: error: 'SdFile' does not name a type
C:\Program Files (x86)\Arduino\libraries\UTFT_tinyFAT\UTFT_tinyFAT.cpp: In member function 'int UTFT_tinyFAT::loadBitmap(int, int, int, int, char*)':
C:\Program Files (x86)\Arduino\libraries\UTFT_tinyFAT\UTFT_tinyFAT.cpp:32: error: 'dataFile' was not declared in this scope
// Demo_Landscape (C)2013 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of the loadBitmap()-function.
// This program requires UTFT_tinyFAT, UTFT v2.41 or higher,
// as well as tinyFAT v3.0 or higher.
// The image files must be present in the root folder
// of a FAT16 formatted SDcard in the module cardslot.
// Please note that this demo only supports the following
// display sizes:
//      220x176
//      320x240
//      400x240
//      480x272
//      800x480
#include <tinyFAT.h>
#include <UTFT.h>
#include <UTFT_tinyFAT.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
UTFT myGLCD(CTE50,38,39,40,41);  // Remember to change the model parameter to suit your display module!
UTFT_tinyFAT myFiles(&myGLCD);
// List of filenames for pictures to display.
 char* files320[]={"PIC301.RAW", "PIC302.RAW", "PIC303.RAW", "PIC304.RAW", "PIC305.RAW", "PIC306.RAW", "PIC307.RAW", "PIC308.RAW", "PIC309.RAW", "PIC310.RAW"}; // 320x240
 char* files400[]={"PIC401.RAW", "PIC402.RAW", "PIC403.RAW", "PIC404.RAW", "PIC405.RAW", "PIC406.RAW", "PIC407.RAW", "PIC408.RAW", "PIC409.RAW", "PIC410.RAW"}; // 400x240
 char* files220[]={"PIC601.RAW", "PIC602.RAW", "PIC603.RAW", "PIC604.RAW", "PIC605.RAW", "PIC606.RAW", "PIC607.RAW", "PIC608.RAW", "PIC609.RAW", "PIC610.RAW"}; // 220x176
char* files480[]={"PIC701.RAW", "PIC702.RAW", "PIC703.RAW", "PIC704.RAW", "PIC705.RAW", "", "", "", "", ""}; // 480x272
char* files800[]={"amazon01.RAW", "amazon01.RAW", "amazon01.RAW", "amazon01.RAW", "amazon01.RAW", "amazon01.RAW", "amazon01.RAW", "amazon01.RAW", "amazon01.RAW", "amazon01.RAW"}; // 800x480
char* files[10];
int picsize_x, picsize_y;
boolean display_rendertime=false;  // Set this to true if you want the rendertime to be displayed after a picture is loaded
boolean display_filename=true;  // Set this to false to disable showing of filename
word res;
long sm, em;
  myGLCD.InitLCD();
  myGLCD.clrScr();
  file.initFAT();
  myGLCD.setColor(255,255,255);
  myGLCD.setFont(SmallFont);
  picsize_x=myGLCD.getDisplayXSize();
  picsize_y=myGLCD.getDisplayYSize();
  switch (picsize_x)
    case 220:
      for (int z=0; z<sizeof(files220)/sizeof(*files220);z++)
        files[z] = files220[z];
    case 320:
      for (int z=0; z<sizeof(files320)/sizeof(*files320);z++)
        files[z] = files320[z];
    case 400:
      for (int z=0; z<sizeof(files400)/sizeof(*files400);z++)
        files[z] = files400[z];
    case 480:
      for (int z=0; z<sizeof(files480)/sizeof(*files480);z++)
        files[z] = files480[z];
    case 800:
      for (int z=0; z<sizeof(files800)/sizeof(*files800);z++)
        files[z] = files800[z];
  for (int i=0; i<(sizeof(files)/sizeof(*files)); i++)
    if (files[i]!="")
      sm=millis();
      res=myFiles.loadBitmap(0, 0, picsize_x, picsize_y, files[i]);
      em=millis();
      if (res!=0)
        if (res==0x10)
          myGLCD.print("File not found...", 0, 0);
          myGLCD.print(files[i], 0, 14);
          myGLCD.print("ERROR: ", 0, 0);
          myGLCD.printNumI(res, 56, 0);
        delay(3000);
        myGLCD.clrScr();
        if (display_rendertime==true)
          myGLCD.print("Rendertime (secs):", 0, 0);
          myGLCD.printNumF(float((em-sm)/1000.0), 2, 160,0);
        if (display_filename==true)
          myGLCD.print(files[i], CENTER, myGLCD.getDisplayYSize()-12);
        delay(3000);
Let's analyze this message. Which of these libraries
#include <UTFT.h>
do you think defines a class called SdFile? Here's a hint: None of them.
I understand your frustration. It gets a bit maddening when an "example" sketch compiles with errors in them. It may not be much help, but you might want to try something from this SD - Arduino Reference. Sometimes grabbing a different library that is supposed to do the same thing works.
