Processing
Hi.
When I try to run any processing code that involves serial communication I get the error:
WARNING: RXTX Version mismatch
Jar version = RXTX-2.2pre1
native lib Version = RXTX-2.2pre2
What can I do to fix this?
Thanks.
WARNING:
Error != Warning.
Sorry, I get the warning. Then I get a whole bunch of errors.
Which can generally be ignored.
Most likely having nothing to do with the warning, not mentioned in your first post, and not shown.
Do you really want help?
Here is my code. It is the example that comes with processing.
import processing.serial.*;
int bgcolor;			     // Background color
int fgcolor;			     // Fill color
Serial myPort;                       // The serial port
int[] serialInArray = new int[3];    // Where we'll put what we receive
int serialCount = 0;                 // A count of how many bytes we receive
int xpos, ypos;		             // Starting position of the ball
boolean firstContact = false;        // Whether we've heard from the microcontroller
  size(256, 256);  // Stage size
  noStroke();      // No border on the next thing drawn
  // Set the starting position of the ball (middle of the stage)
  xpos = width/2;
  ypos = height/2;
  // Print a list of the serial ports, for debugging purposes:
  println(Serial.list());
  // I know that the first port in the serial list on my mac
  // is always my  FTDI adaptor, so I open Serial.list()[0].
  // On Windows machines, this generally opens COM1.
  // Open whatever port is the one you're using.
  String portName = Serial.list()[0];
  myPort = new Serial(this, portName, 9600);
void draw() {
  background(bgcolor);
  fill(fgcolor);
  // Draw the shape
  ellipse(xpos, ypos, 20, 20);
void serialEvent(Serial myPort) {
  // read a byte from the serial port:
  int inByte = myPort.read();
  // if this is the first byte received, and it's an A,
  // clear the serial buffer and note that you've
  // had first contact from the microcontroller.
  // Otherwise, add the incoming byte to the array:
  if (firstContact == false) {
    if (inByte == 'A') {
      myPort.clear();          // clear the serial port buffer
      firstContact = true;     // you've had first contact from the microcontroller
      myPort.write('A');       // ask for more
  else {
    // Add the latest byte from the serial port to array:
    serialInArray[serialCount] = inByte;
    serialCount++;
    // If we have 3 bytes:
    if (serialCount > 2 ) {
      xpos = serialInArray[0];
      ypos = serialInArray[1];
      fgcolor = serialInArray[2];
      // print the values (for debugging purposes only):
      println(xpos + "\t" + ypos + "\t" + fgcolor);
      // Send a capital A to request new sensor readings:
      myPort.write('A');
      // Reset serialCount:
      serialCount = 0;
When I run it I get the errors:
Exception in thread "Animation Thread" java.lang.RuntimeException:
Error inside Serial.()
at processing.serial.Serial.errorMessage(Serial.java:591)
at processing.serial.Serial.(Serial.java:151)
at processing.serial.Serial.(Serial.java:105)
at SerialCallResponse.setup(SerialCallResponse.java:64)
at processing.core.PApplet.handleDraw(PApplet.java:1608)
at processing.core.PApplet.run(PApplet.java:1530)
at java.lang.Thread.run(Thread.java:680)
Thanks.
This tells me that this code:
failed.
What was printed by this code?
Do you have the Arduino connected? Is the Serial Monitor open? Are you able to upload sketches to the Arduino?
The processing program now works but when I try to upload a program to the Arduino I get the error: Programmer not responding even though the arduino's power is on and the right serial port is selected.
How do I fix this?
Thanks.
As in is successfully talking to the Arduino? Or as in starts without throwing an exception?
With the Processing application running? Or shut down? What is attached to the Arduino? Where?
The Processing program starts without throwing an except. When I go to upload the program to the arduino the processing program is not running and the arduino is connected to my mac via the usb cable.
I suppose that that is one definition of "working".
Doesn't answer the question of what, if anything, is attached to the Arduino.
Sorry, I have a led attached to pin 13. But thats all.
