PROGMEM not working with uint32_t?
I'm attempting to use PROGMEM to store an array of uint32_t, and I'm having problems. I can make PROGMEM work with uint16_t, so I suspect (1) I'm doing something wrong, (2) I've found a bug, or (3) the compiler is messing things up.
I'm running arduino.cc 1.8.5.
Here's the code:
const uint32_t PROGMEM array32[] = { 0x00FFEEDD, 0x00CCBBAA, 0x00998877, 0x00665544, 0x00332211, 0x00000000 };
const uint16_t PROGMEM array16[] = { 0x1122, 0x3344, 0x5566, 0x7788, 0x99AA, 0xBBCC };
uint32_t stepStart;
uint16_t index;
  stepStart = millis();
  int step = 3000;
  int color;
  uint32_t mark = millis();
  // print another array value every 3 seconds to avoid overwhelming anyone reading the serial
  if (mark > (stepStart + step)) {
    // output next color
    Serial.print("color ");Serial.print(index,DEC);Serial.print(" at ");
    // if I change uint32_t to uint16_ and array32 to array16 in the next 3 lines, the code works.
    Serial.print((uint32_t) (array32+index));Serial.print(" is ");
    color=(uint32_t) pgm_read_dword_near(array32+index);
    Serial.println( (uint32_t) color,HEX);
    index++;
    index %= 6;
    stepStart = mark;
Serial output:
color 0 at 104 is FFFFEEDD
color 1 at 108 is FFFFBBAA
color 2 at 112 is FFFF8877
color 3 at 116 is 5544
color 4 at 120 is 2211
color 5 at 124 is 0
I've taken a look at the compiler output with a binary editor, and (1) I can see the compiler's smart enough to load only the array I'm using (array32 in this case), (2) it doesn't appear to load the array32 correctly. Here's a portion of the hex file:
0x0120 0DDEEFF00AABBCC0
0x0130 083.:10007000778
0x0140 8990044556600112
0x0150 233000000000083.
Any ideas? Did I miss something basic, or did I potentially find a bug?
gnealhou:
    color=(uint32_t) pgm_read_word_near(array32+index);
http://www.nongnu.org/avr-libc/user-manual/group__avr__pgmspace.html#gaf51eeaa847dd2668d2a66b70ecfb7398
...versus...
http://www.nongnu.org/avr-libc/user-manual/group__avr__pgmspace.html#ga7fa92c0a662403a643859e0f33b0a182
Good eye, but it works the same with pgm_read_dword_near vs. pgm_read_word_near. I just missed it on my last conversion from using array16 to array32.
I edited my original post to reflect the correct use of pgm_read_dword_near, and I have tested it with both macros.
The problem is:
int color;
which should be uint32_t color;
also... I don't think you initialise index
should be
uint16_t index= 0;
Yours,
TonyWilk
TonyWilk:
The problem is:
int color;
:slight_smile: Good catch !
TonyWilk:
The problem is:
int color;
This was the problem (and I got lucky on the non-initialized index). Thanks, Tony!
gnealhou:
Both index and stepStart were initialised to zero by crt0
