Program and global variable storage
Apologies in advance for such a basic question... why does this global array "x" not consume any global variable (or program) storage?
char x[20000];
After compilation:
Sketch uses 6944 bytes (2%) of program storage space. Maximum is 262144 bytes.
Global variables use 3044 bytes (4%) of dynamic memory, leaving 62492 bytes for local variables. Maximum is 65536 bytes.
Because you haven't used it for anything. The compiler optimizes the code, if anything is not used, it doesn't allocate memory or code space for it.
Ah, thanks, adding
x[0] = 'a';
inside the loop forced the allocation:
Global variables use 23044 bytes...
