This is how I programmed multiple AD9833 with Arduino Uno (same for Arduino Due). This method doesn't use SPI port. Connect FSYNC, SDATA AND CLK of the AD9833 to pin 12, 19 and 18 of Arduino. All other AD9833 boards are connected together on the SDATA and CLK while FSYNC pins are connected to pins 0-13 of Arduino board to be programmed sequentially . The code is pretty simple. It works with Arduino Due too.
#include "Wire.h"
int FSYNC = 12; //in my example OR ANY PIN 0-13
int SDATA = 19;
int SCLK = 18;
int i;
int k ;
unsigned long freq;
//byte wave=1;
freq=1; // start with frequency 1HZ as an example
//Application Note AN-1070 from Analog Devices
UpdateRegister(0x2100); UpdateRegister(0x50C7); UpdateRegister(0x4000);
UpdateRegister(0xC000); UpdateRegister(0x2000);
for(k=0;k<14;k++) pinMode(k, OUTPUT);
for (i=0;i<14;i++) digitalWrite(i,HIGH); // put pins 0-13 (FSYNC's) as output HIGH
// pinMode(FSYNC, OUTPUT); pinMode(SDATA, OUTPUT); pinMode(SCLK, OUTPUT);
//digitalWrite(FSYNC, HIGH);digitalWrite(SDATA, LOW);digitalWrite(SCLK, HIGH);
for(k=0;k<14;k++)
UpdateFreq(freq, 0x2000); // for every FSYNC pins 0-13 we update a desired frequency
FSYNC++; //0x2000 is for sine wave, 0x2020 is for square etc
delay(1);
freq++; //increase programmed frequency by 1Hz after each AD9833 was programmed (e.q.)
FSYNC=0; //start FSYNC (AD9833 chip select ) from the beginning
delay(500); // a delay to measure your desired programmed frequencies with a scope
void UpdateFreq(long freq, int form){
// function to program the frequency into registers - no touch
long FreqReg;
unsigned int MSB, LSB;
FreqReg = (freq * pow(2, 28)) / 25000000; // 25MHz Quarz
if (form == 0x2020) FreqReg = FreqReg << 1;
MSB = (int)((FreqReg & 0xFFFC000) >> 14);
LSB = (int)(FreqReg & 0x3FFF);
LSB |= 0x4000;
MSB |= 0x4000;
UpdateRegister(0x2100); // Control Register, Reset Bit DB8
UpdateRegister(LSB); // Frequency Register 0 LSB
UpdateRegister(MSB); // Frequency Register 0 MSB
UpdateRegister(0xC000); // Phase Register
UpdateRegister(form); // Exit Reset
void UpdateRegister(unsigned int data)
{ // function to program registers - no touch
unsigned int pointer = 0x8000;
digitalWrite(FSYNC, LOW);
for (int i=0; i<16; i++){
if ((data & pointer) > 0) {
digitalWrite(SDATA, HIGH);
else {
digitalWrite(SCLK, LOW);
pointer = pointer >> 1 ;
#include "Wire.h"
int SDATA = 19;
int SCLK = 18;
int i;
int k ;
unsigned long freq;
//byte wave=1;
freq = 1; // start with frequency 1HZ as an example
for (k = 0; k < 14; k++) pinMode(k, OUTPUT);
for (i = 0; i < 14; i++) digitalWrite(i, HIGH); // put pins 0-13 (FSYNC's) as output HIGH
delay(1);
FSYNC = 0; //start FSYNC (AD9833 chip select ) from the beginning
void UpdateFreq(long freq, int form) {
long FreqReg;
LSB |= 0x4000;
MSB |= 0x4000;
for (int i = 0; i < 16; i++) {
else {
if you load the correct values on the registers and the output pins to connect to anything you want to control sequentially , then bcse this version dosnt use SPI, there is no reason to fail
