Program taking up too much RAM and flash memory
So, when using an library example as a base of your own program - try to understand every command used in the code before insert it to the your sketch.
here is a cleaned up version of your code, getting rid of Strings (typed here from your code)
//GPS
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
//BMP280 Code
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP280.h>
//SD Card Reader
#include <SD.h>
//GPS
SoftwareSerial mySerial(8, 7);
Adafruit_GPS GPS(&mySerial);
#define GPSECHO  true
//BMP 280
Adafruit_BMP280 bmp;
// buzzer
const byte buzzerPin = 9;
uint32_t lineNumber = 1;
uint32_t timer;
  pinMode(buzzerPin, OUTPUT); //Buzzer
  // BMP
  if (!bmp.begin(0x76)) {
    Serial.println(F("Could not find a valid BMP280 sensor, check wiring!"));
    while (true);
  Serial.println(F("BMP280 Sensor Initiallized!:D"));
  // SD
  if (!SD.begin(10)) {
    Serial.println(F("SD Card Init Failed. Womp Womp D:."));
    while (true);
  Serial.println(F("SD card initialized:D"));
  // GPS
  GPS.begin(9600);
  // For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since
  // the parser doesn't care about other sentences at this time
  // turn on RMC (recommended minimum) and GGA (fix data) including altitude
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
  // turn on only the "minimum recommended" data
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
  // Set the update rate
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);   // 1 Hz update rate
  // Request updates on antenna status, comment out to keep quiet
  GPS.sendCommand(PGCMD_ANTENNA);
  // Ask for firmware version
  mySerial.println(PMTK_Q_RELEASE);
  Serial.println(F("Device Ready"));
  char c = GPS.read();
  if ((c) && (GPSECHO)) Serial.write(c); // debug
  if (GPS.newNMEAreceived() && !GPS.parse(GPS.lastNMEA())) return;  // we can fail to parse a sentence in which case we should just wait for another
  if (millis() - timer > 2000) { // dump data to SD card every 2s if we have a fix
    File dataFile = SD.open("PMData.txt", FILE_WRITE);
    if (dataFile) {
      dataFile.print(lineNumber++);
      dataFile.print(F(", T="));
      dataFile.print(bmp.readTemperature(), 2);
      dataFile.print(F(" °C,  P="));
      dataFile.print(bmp.readPressure() / 100.0, 2);
      dataFile.print(F(" hPa, Alt="));
      dataFile.print(bmp.readAltitude(1013.25), 2);
      dataFile.print(F(" m"));
      if (GPS.fix) {
        dataFile.print(F(", Lat="));
        dataFile.print(GPS.latitude, 6);
        dataFile.print(GPS.lat); // North or South
        dataFile.print(F(", Lon="));
        dataFile.print(GPS.longitude, 6);
        dataFile.print(GPS.lon); // East or West
        dataFile.print(F(", Speed="));
        dataFile.print(GPS.speed, 1);
        dataFile.print(F(", angle="));
        dataFile.print(GPS.angle, 1);
      dataFile.close();
      tone(buzzerPin, 1000, 250);
      Serial.println(F("File failed to open : / "));
    timer = millis();
Unfortunately the combination of all the libraries you picked for your needs makes it unsuitable for the Arduino UNO or Nano ➜ there is not enough RAM.
You can explore other libraries which might be less demanding on RAM or you need a more capable Arduino.
if you want a small form factor, look at some ESP32 boards - some are really small or things like the Seeed Studio XIAO SAMD21
(mind 3.3V versus 5V components)
Or at the same size the XIAO ESP32S3 sense, heaps of memory and an SD card and camera.
Oh wow okay. You didn't have to do that lol. Thanks for the help, I'll look through libraries to learn about their functions and uses more so I can write better code. I really appreciate your help and I'll look into smaller form factor chips.
