Program within program and waiting for change ?
Dear Arduino community
I am trying to make something but I'm not really sure how to solve this, I tried to google it but I can't really find what I need.
First:
I want to log temperature every 2 hours lets say, I can use a delay of two hours but that will make my sketch stop for 2 hours before checking the gas every 10 minutes.
I am wondering what kind of function I have to use, currently I am using the follwing:
(Code to read temperature sensors)
delay(2hours) --> (I know it must be 2 hours in MS)
delay(10 minutes)
I basicly want to create 2 loops not affecting each other with those delays.
Second problem:
I have a setup which checks light sensitivity to conclude if a door is open or shut. Open means the analog signal of the LDR is below 900 and closed means it's above 900. When I serialprint the data it keeps printing 'door closed' because I am using a regular delay and it keeps concluding that it's closed. I want to only print something when the LDR condition is changed. Let's say when the door is closed and stays closed for 10 minutes I don't care and don't want to see anything on my serialmonitor. When the door opens I want to see appear 'Door opened' and that's it. When the door stays open I don't want to see any messages.
Third:
A MQ-2 gas sensor has as analog output a bunch of numbers (doh) but how can I know what these numbers mean like % of gas in the air,... ?
I'm new to arduino so these problems are probably peanuts to most of you.
Thank you for your help!
Tom
Clue #1 it's called millis millis() - Arduino Reference
It lets you call a function without using a blocking delay.
Clue #2 called a if then statement
if (LDRLess < 900)
  // Tell me here
  Serial.print("DOORS CLOSED.")
Clue #3 Arduino Playground - MQGasSensors
Delta_G:
Problem 2:
Look at the State Change example for some inspiration. You need to remember the last state of the door in some variable and only do your printing when the new state of the door is not the same as the old state of the door.
How do I add this to the following code?
The example is done with a LED and I don't have the experience on how to do it with variables.
int sensorReading;
int PinLDR = A1
  sensorReading=analogRead(PinLDR);
 if (sensorReading<900)
    Serial.println("door open");
  else Serial.println("door closed");
Thanks
Jinx
You need to add a variable to keep track of the state of the door.
bool doorOpen = false;
When the condition under which the door should be open changes (the door should be open but is not), open the door and change the recorded state:
if(sensorReading<900)
   // Door should be open
   if(!doorOpen)
      OpenDoor();
      doorOpen = true;
You also need to deal with the state where the door is open but should be closed, as well as where the door is open and should be open, and where the door is closed and should be closed (the last two don't require actually doing anything but thinking about them).
