Programmer is not responding/in sync for only one program
Trying to run some code I downloaded from GitHub on my Arduino Uno R3. I run into this error when I try to % make upload from the terminal:
I've tried most of the strategies online (like this) but it didn't work. The weirdest part is I've tried running other example programs such as blink from the Arduino IDE, and it seems to upload and work perfectly fine on the same Uno.
Any advice on what to do? I've been stuck here forever, so it would really mean a lot!
Wrong baudrate. From boards.txt
uno.upload.speed=115200
I've tried changing the MONITOR_BAUDRATE parameter in the makefile, but to no avail. :frowning:
Try the blink sketch, it is in examples. If that does not work, be sure the correct board is selected.
@gilshultz Already tried that — surprisingly blink still runs. It's just this program that's not uploading.
Compare the command of a successful upload to that if a failed upload. Any difference (except for filename)?
Change the blink time to about 4000 for the on and 800 for the off and upload it. Then see if the blink changes. Let us know.
@sterretje It just uploads and runs without the error message. A successful upload executes avrdude and prints out the regular stuff below. Sorry if I'm missing something :frowning:
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Users/user/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
         User configuration file is "/Users/user/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem14201
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/var/folders/_c/4k453cvx1s1c6hs_spyjd06h0000gn/T/arduino_build_31196/Blink.ino.hex"
avrdude: writing flash (932 bytes):
Writing | ################################################## | 100% 0.19s
avrdude: 932 bytes of flash written
avrdude: verifying flash memory against /var/folders/_c/4k453cvx1s1c6hs_spyjd06h0000gn/T/arduino_build_31196/Blink.ino.hex:
avrdude: load data flash data from input file /var/folders/_c/4k453cvx1s1c6hs_spyjd06h0000gn/T/arduino_build_31196/Blink.ino.hex:
avrdude: input file /var/folders/_c/4k453cvx1s1c6hs_spyjd06h0000gn/T/arduino_build_31196/Blink.ino.hex contains 932 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.14s
avrdude: verifying ...
avrdude: 932 bytes of flash verified
avrdude done.  Thank you.
@gilshultz The blink changes and runs fine. I'm also running blink from the Arduino IDE but I'm running this program (that isn't uploading) on the terminal. Not sure if that makes a difference?
That is what I expect to see when you upload for an Uno. However, the command line in the image in the opening post states 57600.
So compare the two commands, not the output of the commands; post both here if in doubt,
That does make a difference. Do it all with the same programing setup. The IDE has a specific protocol that it follows for uploading, the terminal normally would nol.
