Hello,
I have a Raspberry Pi connected to the home wifi, and an Arduino nano connected to Raspberry by usb, to collect data from weather sensors. I connect to Raspberry by remote access VNC.
I have installed the Arduino IDE in Raspberry. I was able to upload a short sketch and run on Arduino and see the output by console; but when I try to upload a longer sketch, I get an error:
After this happens, I can not load the short sketch either.
Hello,
thanks to all. I'll start with the last one:
hammy:
That sounds like it’s losing the USB port.
This seems a hard way to do things - why not just program the Arduino from a PC of Mac ?
I have the Arduino and the Raspberry in a watertight boxes on a mast where the anemometer, the wind vane and the rain gauge are located. Raspberry is connected to the wifi of the house. And I connect to Raspberry by VNC remote access. It is very comfortable, I have the Raspberry desktop on the screen of my Linux PC. To program on my PC I would have to disconnect the connections, remove from the box, reassemble ...
I will try the other options that suggest me in the answers.
Binary sketch size: 2,294 bytes (of a 30,720 byte maximum)
avrdude: stk500_cmd(): programmer is out of sync
avr_read(): error reading address 0x0000
read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x9ev
B) In another series of tests:
Done uploading.
Binary sketch size: 2,150 bytes (of a 30,720 byte maximum)
Done uploading.
Binary sketch size: 2,486 bytes (of a 30,720 byte maximum
Binary sketch size: 2,870 bytes (of a 30,720 byte maximum)
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x6e
I work everyday with arduino and Raspberry: although I do not use daily the Ri to program arduino (I used it long time ago) your program is so small (by the way: an opening parenthesis is missing; sure this is not the problem) that it shouldn't pose any problem to be compiled and uploaded.
I'd try to do it by using a PC (just to make sure it works); then, I'd download the arduino IDE again (to Linux). Perhaps you are using the on line version; I've never used it, so I cannot give you any advice if this is the case. I am a native skeptical, so I'd rather prefer using local software ...
Regards
