Programming for two button switches blink
Hi, i have stumbled upon the following problem today in my programning.
I needed a 2 buttons to act as a lever(switch) and make leds blink, and found this code: http://www.arduino.cc/en/Tutorial/Switch, comparing the previous and current button states to turn and led on.
Then for the second button i just copied the code and just changed the variables as so:
int inPin = 2;
int inPin2 = 3;
int outPin2 = 12;
int outPin = 13;
int state = HIGH;
int state2 = HIGH;
int reading;
int reading2;
int previous = LOW;
int previous2 = LOW;
long time = 0;
long time2 = 0;
long debounce2 = 200;
long debounce = 200;
pinMode(inPin, INPUT);
pinMode(inPin2, INPUT);
pinMode(outPin, OUTPUT);
pinMode(outPin2, OUTPUT);
reading = digitalRead(inPin);
reading = digitalRead(inPin2);
if (reading == HIGH && previous == LOW && millis() - time > debounce) {
if (state == HIGH)
state = LOW;
state = HIGH;
time = millis();
if (reading2 == HIGH && previous2 == LOW && millis() - time2 > debounce2) {
if (state2 == HIGH)
state = LOW;
state = HIGH;
time = millis()
digitalWrite(outPin, state);
delay(450);
digitalWrite(outPin, LOW);
digitalWrite(outPin2, state2);
delay(450);
digitalWrite(outPin2, LOW);
delay(450);
previous = reading;
previous2 = reading2;
In turn the first initial button and led still blinked and stopped when the button was pressed, yet the second button didnt work as a switch and behaved like a normal button, corresponding led only blinking when the button was pressed. Can anyone help me either develop this code to work or explain to me what I am doing wrong. Thanks in advance
The ole copy/paste bug...
that might be it but if it wasnt showing me a bug
Where do you get reading2 from?
All variables used with millis timing should be unsigned long.
reading2 would be the reading of the second button
Change this...
To this...
  reading2 = digitalRead(inPin2);
i did but the problem is still at hand, it will not change states, the led will only turn on a perm connection.
    if (state2 == HIGH)
      state = LOW;
      state = HIGH;
Should be state2 not state.
