I want to program the Arduino to control the rotation of the DC motor. I have tried a lot, but a problem occurs. When I push the joystick forward, it starts rotating, and when I move it back, the rotation reverses, but if I push it all the way back, the motor turns off. What is the solution?
You, yourself, can find the problem by using serial.Print() to show the values being returned by the code reading the joystick values. When you know the values causing the problem, fix the problem.
Do you have a sketch you can show us and maybe a schimatic?
Are you using the Servo library etc?
Br Max
You have a sketch. Show your sketch so it may be fixed.
WOKWI files
sketch.ino
#define VERT_PIN A0
#define HORZ_PIN A1
#define SEL_PIN 2
#define enaLeft 9
#define fwdLeft 8
#define revLeft 12
#define enaRight 5
#define fwdRight 4
#define revRight 7
int vert, oldVert = 512, horz, oldHorz = 512, drive;
bool sel, oldSel = 1;
welcome();
pinMode(enaLeft, OUTPUT);
pinMode(fwdLeft, OUTPUT);
pinMode(revLeft, OUTPUT);
pinMode(enaRight, OUTPUT);
pinMode(fwdRight, OUTPUT);
pinMode(revRight, OUTPUT);
pinMode(VERT_PIN, INPUT);
pinMode(HORZ_PIN, INPUT);
pinMode(SEL_PIN, INPUT_PULLUP);
readJoystick();
drive = map(vert, 0, 1023, -255, 255);
if (drive > 20) // stick up
forward();
if (drive < -20) // stick down
reverse();
if (drive <= 20 || drive >= -20) // deadband
stop();
void forward() {
digitalWrite(fwdLeft, HIGH); // forward polarity
digitalWrite(revLeft, LOW);
digitalWrite(fwdRight, LOW); // right motor mounted backwards
digitalWrite(revRight, HIGH);
analogWrite(enaLeft, drive); // PWM speed
analogWrite(enaRight, drive);
void reverse() {
digitalWrite(fwdLeft, LOW); // reverse polarity
digitalWrite(revLeft, HIGH);
digitalWrite(fwdRight, HIGH);
digitalWrite(revRight, LOW);
analogWrite(enaLeft, -drive); // negate the PWM value
analogWrite(enaRight, -drive);
void stop() { // stop the motors with stick in deadband
analogWrite(enaLeft, LOW);
analogWrite(enaRight, LOW);
void readJoystick() {
vert = analogRead(VERT_PIN);
// debug printing
// horz = analogRead(HORZ_PIN);
// sel = digitalRead(SEL_PIN);
// delay(100);
// if (oldVert != vert) {
// Serial.println(vert);
// oldVert = vert;
// if (oldHorz != horz) {
// Serial.println(horz);
// oldHorz = horz;
// if (oldSel != sel) {
// Serial.println(sel);
// oldSel = sel;
void welcome() {
Serial.println("DC motor simulation with joystick control for forward and reverse.");
diagram.json
"version": 1,
"author": "Anonymous maker",
"editor": "wokwi",
"parts": [
{ "type": "wokwi-arduino-nano", "id": "nano", "top": -14.4, "left": -0.5, "attrs": {} },
"type": "wokwi-analog-joystick",
"id": "joystick1",
"top": -154.2,
"left": 159,
"attrs": {}
"type": "wokwi-led",
"id": "led1",
"top": -135.6,
"left": 112.2,
"rotate": 90,
"attrs": { "color": "green" }
"id": "led2",
"top": -78,
"left": 112.2,
"rotate": 90,
"id": "led3",
"top": -106.8,
"left": 112.2,
"rotate": 90,
"attrs": { "color": "white" }
"id": "led4",
"top": -135.6,
"left": -27.4,
"rotate": 270,
"attrs": { "color": "red", "flip": "1" }
"id": "led5",
"top": -106.8,
"left": -27.4,
"rotate": 270,
"attrs": { "color": "white", "flip": "1" }
"id": "led6",
"top": -78,
"left": -27.4,
"rotate": 270,
"connections": [
[ "joystick1:VCC", "nano:5V", "red", [ "v96", "h-67.2" ] ],
[ "joystick1:GND", "nano:GND.1", "black", [ "v105.6", "h-86.4" ] ],
[ "nano:A0", "joystick1:VERT", "green", [ "v28.8", "h153.6" ] ],
[ "nano:A1", "joystick1:HORZ", "green", [ "v38.4", "h153.6" ] ],
[ "joystick1:SEL", "nano:2", "green", [ "v19.2", "h-96" ] ],
[ "nano:4", "led2:A", "green", [ "v0" ] ],
[ "nano:7", "led1:A", "green", [ "v0" ] ],
[ "nano:5", "led3:A", "green", [ "v0" ] ],
[ "nano:8", "led4:A", "green", [ "v0" ] ],
[ "nano:12", "led6:A", "green", [ "v0" ] ],
[ "nano:9", "led5:A", "green", [ "v0" ] ],
[ "nano:GND.2", "led2:C", "black", [ "v-19.2", "h-48", "v-28.8" ] ],
[ "nano:GND.2", "led6:C", "black", [ "v-19.2", "h-96", "v-28.8" ] ],
[ "nano:GND.2", "led3:C", "black", [ "v-19.2", "h-48", "v-57.6" ] ],
[ "nano:GND.2", "led1:C", "black", [ "v-19.2", "h-48", "v-86.4" ] ],
[ "nano:GND.2", "led5:C", "black", [ "v-19.2", "h-96", "v-57.6" ] ],
[ "nano:GND.2", "led4:C", "black", [ "v-19.2", "h-96", "v-86.4" ] ]
"dependencies": {}
