Hello!
I'm attempting to do this project, where I write data measured by an accelerometer & altimeter to a SD card. The output, however, is behaving very weirdly. Instead of writing, it repeats the setup. Nothing is written to the file.
/*############### VIRTUABOTIX BASIC ACCELEROMETER CODE #########################
This code is meant to serve as the most basic example of how to read out
from the X Y and Z axis as raw sensor readings.
 TO PIN A0  #                                                    # To 5 Volts
       #    #     X Axis                              5 Volt     #    #
 TO PIN A1  #                                                    #
       #    #     Y Axis                              3.3 Volt   #    #
 TO PIN A2  #                                                    # To Ground
       #    #     Z Axis                              Ground     #    #
 TO PIN 2
       #    #     Sleep                 GS (Sensitivity Select)  #    #
       #    #     0G                             ST (Self Test)  #    #
 * Find more free code, and great products at http://www.virtuabotix.com/
 * $Author: Mr. Joe $
 * $Date: 2011-11-5 $
 * $Revision: 0     $
  * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4
int sleepPin= 2; //Turning sleep high turns on the Accelerometer
int xpin= A0;
int ypin = A1;
int zpin = A2;
int gpin = A3;
#include <Wire.h>
#include "IntersemaBaro.h"
#include <SD.h>
Intersema::BaroPressure_MS5607B baro(true);
  baro.init();
  pinMode(sleepPin, OUTPUT);
  digitalWrite(sleepPin, HIGH);
  pinMode(xpin, INPUT);
  digitalWrite(xpin, HIGH);
  pinMode(ypin, INPUT);
  digitalWrite(ypin, HIGH);
  pinMode(zpin, INPUT);
  digitalWrite(zpin, HIGH);
  pinMode(gpin, INPUT);
  digitalWrite(gpin, HIGH);
  pinMode(10, OUTPUT);
  if (!SD.begin(4)) {
    return;
  Serial.println("Complete!");
  delay(2000);
  Serial.println("Attempting to open file.");
  File  myFile = SD.open("datalogger.txt", FILE_WRITE);
  Serial.println("File has opened");
  int alt = baro.getHeightCentiMeters();
  if (myFile) {
      Serial.println("Writing to file");
      myFile.print("Time: ");
      myFile.print(millis()/1000);
      myFile.print(", Centimeters: ");
      myFile.print((float)(alt));
      myFile.print(", Feet: ");
      myFile.println((float)(alt) / 30.48);
      myFile.print("X Reading: ");
      myFile.println(analogRead(xpin), DEC);
      myFile.print("Y Reading: ");
      myFile.println(analogRead(ypin), DEC);
      myFile.print("Z Reading: ");
      myFile.println(analogRead(zpin), DEC);
      myFile.print("0G Reading: ");
      myFile.println(analogRead(gpin), DEC);
      myFile.println("----------------------------");
      myFile.close();
      Serial.println("File has been closed");
  delay(5000);
Here is my output,
Complete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
A´Complete!
A´Complete!
AtComplete!
AtComplete!
AtComplete!
A´Complete!
AtComplete!
A´Complete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
AtComplete!
A´Complete!
I'm completely unsure what I'm doing wrong. Any help would be greatly appreciated.
Thank you!
