I have a BTS project in which i wanted to use arduino,
my goal is to use arduino to create an aim system for a bot,
the bot need to shoot inside three littles holes in a target,
And i know i need to use two steppers motors for the aim deplacement,
but i don't know how to aim the targets ( the bot need to be automatic)
tell me if you need further details
thank you !!
Use the same system you use when you aim at something. Two cameras spaced a fixed distance apart. Take pictures. Find the holes in each picture. Move the cameras so the hole in each picture is exactly the same distance from the frame edges in each picture. The shot will be exactly where the cameras are aimed.
It seem pretty difficult
i doesn't have a lot of knowlegde on this topic
How the bot will know where the hole is and how it will command te position to the motor
It is not novice work.
The image scan that you program.
You program the motors.
Learn to program (1) using "C", (2) the Arduino (start with the Built-In Examples), (3) each device you will use, (4) all the devices together.
I would start with servos and perhaps a light on the target to make things easier to start .
Have a google too , there are some similar projects for inspiration.
You need some experience for this
thanks for the process !
I will see but i'm not sur i'm allowed to change things on the targets
