I'm trying to create a circuit that monitors the moisture, light and temperature of a plant. However, I've been experiencing problem after problem. Essentially, when one of these conditions is off, a piezo needs to go off, and a message needs to be printed to the LCD. Except, for some reason, the LCD doesn't work at all here, the values being pulled out are all out of whack, and the piezo just goes off indefinitely.
Here is the Tinkercad mockup, that way you can go in and play around with the circuit: Login - Tinkercad
Here's a picture:
Here's the code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int moistureInputPin = A0;
int moistureOutputPin = A1;
int temperaturePin = A2;
int lightPin = A3;
int piezoPin = 8;
int temperature;
int light;
int moisture;
float coldestTemp = 50;
float hottestTemp = 95;
int minLight = 10;
int minMoisture = 100;
bool prevLightFine = true;
bool prevTempFine = true;
bool prevMoistureFine = true;
bool conditionsRight;
bool prevConditionsState;
lcd.begin(16, 2);
temperature = (((analogRead(temperaturePin) / 1024.0) * 5.0) - 0.5) * 100;
light = analogRead(lightPin);
digitalWrite(moistureOutputPin, HIGH);
delay(10);
moisture = analogRead(moistureInputPin);
digitalWrite(moistureOutputPin, LOW);
conditionsRight = (temperature < hottestTemp && temperature > coldestTemp) && (light >= minLight) && (moisture >= minMoisture);
Serial.print("Moisture: ");
Serial.print(moisture);
Serial.print(" Light: ");
Serial.print(light);
Serial.print(" Temperature: ");
Serial.println(temperature);
if (moisture < minMoisture) {
if (prevMoistureFine) {
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Moisture low!");
tone(piezoPin, 349);
if (light < minLight) {
if (prevLightFine) {
lcd.clear();
lcd.print("Light low!");
if (temperature > hottestTemp) {
if (prevTempFine) {
lcd.clear();
lcd.print("Too hot!");
if (temperature < coldestTemp) {
if (prevTempFine) {
lcd.clear();
lcd.print("Too cold!");
if (conditionsRight == true && prevConditionsState == false) {
lcd.clear();
lcd.print("All good.");
noTone(piezoPin);
prevLightFine = light > minLight;
prevTempFine = temperature > coldestTemp && temperature < hottestTemp;
prevMoistureFine = moisture > minMoisture;
prevConditionsState = conditionsRight;
What's wrong with it? I think it's probably some kind of programming error.
