Hi all,
I am working on my first Arduino project and would need some help from you guys as I am a SW engineer with very basic knowledge of electronics.
Short description of the project:
I would like to switch ON / OFF a siren using a 12V trigger signal which is generated by another device. However, I want to ignore the trigger signals which are shorter than cca. 3 seconds.
A simple diagram representing the idea:
That being said, I can think of 2 ideas on how to solve this challenge:
- With an electrical circuit (I have zero idea on how to do that)
- With an Arduino and a relay
I figured I'd go with the second option simply because I believe I can implement it with some support from you guys But I am open to hear reasons why option 1 would be much better.
Anyway, going for the second option, here is a diagram of how I would connect everything together:
Here are the components from the diagram, which I was planning on using:
Component A
Component B
Component C
Component D
Here are some of the doubts / questions I have about the diagram I drew:
-Are the chosen components OK for what I am doing?
-Can Arduino and relay be powered by the same power adapter?
-Should there be a ground connection between Arduino and Triggering device?
-Can I get rid of the relay completely and use Arduino as a relay?
-Are all the electrical connections OK?
-Are the AC / DC currents handled correctly?
-Will this work at all?
-Is there anything that could be done better?
Thank you very much for your inputs! Looking forward to your feedback.
