Protected members and inheritance
Can anyone explain why the following does not work?
class Base {
  protected:
    Base(){};
    bool tgl(uint8_t);
bool Base::tgl(uint8_t _id) {
  static bool _toggle[6];
  _toggle[_id] = (_toggle[_id] ? 0 : 1);
  return _toggle[_id];
class Derived: public Base {
    Derived() {};
  public:
    static Derived& initialize();
Derived& Derived::initialize() {
  static Derived _instance;
  return _instance;
Derived& derived = Derived::initialize();
  Serial.println(derived.tgl(5)); // Error within this context  bool Base::tgl(uint8_t) is protected
Making Base::tgl(uint8_t) a public member does what I want, it simply outputs alternating 1's and 0's to the serial monitor. But the fact that it works just confuses me further, because I am calling the protected constructor Base() when I create an instance of Derived with no problems. So why can't I can't call the protected member function tgl() from my derived instance, if that member is indeed protected?
jwllorens:
Because you're not calling tgl() from your derived instance, you're calling it from loop()?
gfvalvo:
Derp. I just realized that right before I read your reply. Thanks for pointing it out!
