protection for digital input pin
I have a switched mode power supply outputting 12v into my sensor. When my sensor is HIGH the output will be 12v, and so I will use a voltage divider to reduce this to 4.5v. Do the following values look ok?
Vin = 12v
r1 = 10K
r2 = 6K
Vout = 4.5v
Is there any thing else I should add to this protection circuit?
Provided your sensor is connected across R2, those values seem fine.
You could give yourself a bigger margin of safety against over-voltage. Something like 27k and 10k will give 3.24V for 12V and be safe upto 18.5V.
Using higher value resistors provides even more protection against damage (but the values I chosen stay below the 10k impedance limit recommended for the analog inputs to guarantee full accuracy).
MarkT:
That makes sense. What voltage does an Arduino consider HIGH?
I was thinking of connecting like in the attached diagram, is this correct?
davivid:
Yes, that would measure across R2 or in other words just measuring R2's voltage drop.
Edit: Typo, extraneous "be"
Better still put a 5V1 zener across your input pin as well.
http://www.thebox.myzen.co.uk/Tutorial/Protection.html
Thanks for link.
Is the following diode suitable?
0.5W Zener Diodes
BZX79C 5V1
Consider buying a Ruggeduino. They have Zeners and more across all input pins. Beautiful design.
Yes. :slight_smile:
Hey, let's dig up this :stuck_out_tongue:
So I'm doing a project where I'll hook up the arduino power to 12v, from the car lighter. In my project I'll have a 7805 voltage regulator, so it will break down the 12v to 5v.
I'll use 12v to power the arduino. And the 5v from the voltage regulator to a sliding switch that I'll read as input on a digital pin.
I'm afraid that over-voltage can occur on the digital input, so I was thinking about protecting the digital pin with the following circuit:
that I've read from this link:
Is this a good way to protect it?
Thanks,
Tiago
It's my page so yes I think it is good especially if you are only protecting against transients. If the voltage is going to be constantly over 5V then make that resistor something like 100R.
Grumpy_Mike:
The datasheet section "I/O pins" says:
All I/O pins have protection diodes to both VCC and Ground
So you don't need any more.
(Assuming you've limited the number of amps that can reach the pin, eg. though a 10k resistor).
Yes you do. 1mA is the maximum current that should flow through the internal protection diodes.
Grumpy_Mike:
Got it :slight_smile:
I don't have a 100pF can I use other values?
Grumpy_Mike:
Not if you use a 10K series resistor as he suggested, that will limit the current to (12 - 5)/10 = 0.7mA. But personally, I would use a higher value, e.g. 47K or 100K.
Grumpy_Mike:
The thing is that once you start putting 10K series resistors on inputs your noise immunity is shot and it limits the rise time of the signals. That is why I have a 22R series resistor so the protection circuit does not end up crippling the signal.
Grumpy_Mike:
What impact the capacitor values have?
Yes, using other values will control the balance between protection against spikes and disrupting the input signal.
The capacitor absorbs voltage spikes ( good ) and also slows down the input rise time ( bad ) .
