i have a ps/2 keyboard hooked up my arduino and it is working great but i want it to do something after no key is pressed for 1 min, how would i go about that?
maintain a variable that tracks the value of millis ( ) each time a keystroke is pressed (maybe call it lastKeyTime). In your loop, check to see if the current value of millis ( ) minus the remembered value is larger than your desired inactivity time (60000).
ya thats what i thought i would do but and this is going to sound like a newbie question(because I'm a noob) but i don't really know how to do that.
// declare the lastKeyTime variable in the globals (before setup)
long lastKeyTime;
const int idleTime=60000;
void setup ( ) {
loop ( ) {
// somewhere in your code just after receiving a keypress
lastKeyTime = millis ( );
// somewhere else in the code, in a place that isn't conditional on processing a keypress
if ( millis ( ) - lastKeyTime > idleTime ) DoThatThingYouWantedToDoAfterAMinuteOfIdleTime ( );
Something like that... ![]()
so ya i got tat but what i need to know is how to tell if a key is pressed with out checking every byte. sorry about not being clear
I don't know if this helps any but this is my code :
#include <PS2Keyboard.h>
#define KBD_CLK_PIN 3
#define KBD_DATA_PIN 4
#define CHAR_ESC "\x1B"
#define CHAR_BS "\x08"
#define CHAR_LF "\x0A"
#define CHAR_CR "\x0D"
int r = 2;
int y = 7;
PS2Keyboard keyboard;
pinMode(y, OUTPUT);
pinMode(r, OUTPUT);
Serial.begin(57600);
Serial.print(CHAR_ESC "v");
Serial.print("C.O.S.");
Serial.print(CHAR_LF);
Serial.print(CHAR_CR);
Serial.print("version 1.1.0 BETA 2.1.0");
Serial.print("KEYBOARD AND T.V. USE");
Serial.print(CHAR_ESC "x5");
digitalWrite(r, HIGH);
delay(10000);
digitalWrite(r, LOW);
Serial.print(CHAR_ESC "y5");
Serial.print(CHAR_ESC "E");
keyboard.begin(KBD_DATA_PIN);
#define is_printable(c) (!(c&0x80)) // don't print if top bit is set
if(keyboard.available()) {
// reading the "extra" bits is optional
byte extra = keyboard.read_extra(); // must read extra before reading the character byte
byte c = keyboard.read();
boolean ctrl = extra & 1; // <ctrl> is bit 0
boolean alt = extra & 2; // <alt> is bit 1
if (ctrl) Serial.print('^');
if (alt) Serial.print('_');
if (c==PS2_KC_UP) Serial.print(CHAR_ESC "A");
else if (c==PS2_KC_DOWN) Serial.print(CHAR_ESC "B");
else if (c==PS2_KC_RIGHT) Serial.print(CHAR_ESC "C");
else if (c==PS2_KC_LEFT) Serial.print(CHAR_ESC "D");
else if (c==PS2_KC_DEL) Serial.print(CHAR_ESC "E");
else if (c==PS2_KC_BKSP) {
Serial.print(CHAR_BS);
Serial.print(" ");
else if (c==PS2_KC_PGUP) {
Serial.print(CHAR_ESC "y:");
digitalWrite(y, LOW);
else if (c==PS2_KC_PGDN) {
Serial.print(CHAR_ESC "x:");
digitalWrite(y, HIGH);
else if (c==PS2_KC_ESC) Serial.print(CHAR_ESC "Q");
else if ( is_printable(c) ) Serial.print(c); // don't print any untrapped special characters
Not sure what you mean by "checking every byte", but keyboard.available() is already telling you whether or not a key was pressed.
the keyboard sends out what i think is a hex code for every key pressed but it takes up to much room in my code to do that.
To do what?
There's a difference between checking "if a key is pressed" and checking "what key is pressed". Which are you trying to do? Why did you connect the ps2 keyboard, anyway?
