PT100 reading is not available on my brandnew PMC board. Program using the PLC IDE. All 3 channels activated for PT100. Measurement on aurduino uno with MX31865 gives perfect reading, so i assume my PT100 is OK.
How about a schematic and some links to technical information on your hardware items.
OP seems to have found a way around it in another thread.
Leo..
Hi
The portenta machine control has just 3 wires PT100 and following program
temp:= sysTempProbes[0].temperature;
but that one doesn’t give any result.
The ID2.0 does give a figure, but that doesn’t change when I put the PT100 in ice or boiling water!!
The sysEncodersInput does work fine
I have the same issue. In the standard Arduino IDE (not the PLC IDE), the RTD works, so it must be an issue with the PLC IDE.
Hallo, with the example in IDE the RTD is indeed working. I will ask Arduino to fix the PLC IDE library
i got a message from Arduino that the new version 1.0.3 is available. I installed it, but now i have troubles updating my Portenta. The thing doesn't react anymore, even after a hard reset???
