PT100 Signal Conditioning , LED's and Arduino Uno
Hello all
Just started working with the Arduino Uno. I have completed most of the basic projects so I thought I'd be a little more adventurous...
I have a PT100 which I have designed a signal conditioning circuit for which consists of a Wheatstone bridge, Instrumentation Amplifier and low-pass filter.
I have a supply voltage of 5 volts DC going into the circuit. I am getting a voltage range of 0.5 volts to 4 volts output.
Is it just a case of connecting this to the analogue pin of the Arduino board and writing a programme?
I would then like to design code for the Arduino that would turn on/off LED's at certain temperatures.
Any advice would be much appreciated
Thanks Robert
The analogue inputs can handle up to 5v so this is ok to connect directly. (Make sure the Gnd is also common.)
A full circuit may help us to advise on the program.
Weedpharma
Hello
I have attached a copy of my circuit.
Thanks for the advice
circuit.pdf (17 KB)
Seems like a complicated circuit for temperature sensing!
If the output varies with a peak of less than 5v, simply read the analogue input and check the value. If the value is what you want, then turn on a LED. If not, then turn it off.
When you check the value use > a value, not an exact value as the reading will vary around a point.
Weedpharma
