I am using esp8266's as sensors connecting to Home Assistant through a Mosquitto MQTT broker. I have several sensors that are set up and working properly. I tried today to add another sensor and cannot get it to transfer information to the broker.
Using MQTTspy I have verified that the broker is receiving data from the other sensors. I also verified that I can publish a value from MQTTspy and have it show up on the Home Assistant user interface.
The esp8266 thinks it is sending data to the broker, but MQTTspy doesn't see it.
The code is a bit of a mashup. I hope that I won't offend somebodies sensibility with my coding style.
This code has worked in the past. The only thing that I can guess is wrong is a problem with a library update.
Perhaps somebody with a sharp eye will discern something that I am doing incorrectly.
Here is some diagnostic output from the Arduino com port.
INFO: Connecting to [redacted]
INFO: WiFi connected
INFO: IP address:
192.168.1.177
INFO: Attempting MQTT connection...INFO: connected
29.28
0.00
68.92
State topic: bme280_1
Data: {"pressure":"29.28","humidity":"0.00","temperature":"68.92"}
Message length: 61
INFO: Closing the MQTT connection
INFO: Closing the Wifi connection
This is the code running on the esp8266. I have omitted the credentials for obvious reasons.
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
#include "credentials.h"
#include <stdint.h>
#include "SparkFunBME280.h"
#include "Wire.h"
//Global sensor object
BME280 mySensor;
WiFiClient wifiClient;
PubSubClient client(wifiClient);
// function called to publish the temperature and the humidity
void publishData(float p_pressure, float p_humidity, float p_temperature) {
// create a JSON object
// doc : https://github.com/bblanchon/ArduinoJson/wiki/API%20Reference
StaticJsonBuffer<200> jsonBuffer;
JsonObject& root = jsonBuffer.createObject();
// INFO: the data must be converted into a string; a problem occurs when using floats...
root["pressure"] = (String)p_pressure;
root["humidity"] = (String)p_humidity;
root["temperature"] = (String)p_temperature;
// root.prettyPrintTo(Serial);
// Serial.println("");
char data[200];
root.printTo(data, root.measureLength() + 1);
client.publish(MQTT_SENSOR_TOPIC, data, true);
// diagnostic print
Serial.print("State topic: ");
Serial.println(MQTT_SENSOR_TOPIC);
Serial.print("Data: ");
Serial.println(data);
Serial.print("Message length: ");
Serial.println(root.measureLength() + 1);
// function called when a MQTT message arrived
void callback(char* p_topic, byte* p_payload, unsigned int p_length)
void reconnect()
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("INFO: Attempting MQTT connection...");
// Attempt to connect
if (client.connect(MQTT_CLIENT_ID, MQTT_USER, MQTT_PASSWORD))
Serial.println("INFO: connected"); \
Serial.print("ERROR: failed, rc=");
Serial.print(client.state());
Serial.println("DEBUG: try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
//***Driver settings********************************//
//specify I2C address. Can be 0x76(default) or 0x77
mySensor.settings.commInterface = I2C_MODE;
mySensor.settings.I2CAddress = 0x76;
//***Operation settings*****************************//
//renMode can be:
// 0, Sleep mode
// 1 or 2, Forced mode
// 3, Normal mode
mySensor.settings.runMode = 3; //Normal mode
//tStandby can be:
// 0, 0.5ms
// 1, 62.5ms
// 2, 125ms
// 3, 250ms
// 4, 500ms
// 5, 1000ms
// 6, 10ms
// 7, 20ms
mySensor.settings.tStandby = 6;
//filter can be off or number of FIR coefficients to use:
// 0, filter off
// 1, coefficients = 2
// 2, coefficients = 4
// 3, coefficients = 8
// 4, coefficients = 16
mySensor.settings.filter = 4;
//tempOverSample can be:
// 0, skipped
// 1 through 5, oversampling *1, *2, *4, *8, *16 respectively
mySensor.settings.tempOverSample = 4;
//pressOverSample can be:
// 0, skipped
mySensor.settings.pressOverSample = 4;
//humidOverSample can be:
// 0, skipped
mySensor.settings.humidOverSample = 4;
// init the serial
Serial.print("Program Started\n");
Serial.print("Starting BME280... result of .begin(): 0x");
//Calling .begin() causes the settings to be loaded
delay(10); //Make sure sensor had enough time to turn on. BME280 requires 2ms to start up.
Serial.println(mySensor.begin(), HEX);
// init the WiFi connection
Serial.print("INFO: Connecting to ");
WiFi.mode(WIFI_STA);
Serial.println(WIFI_SSID);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.println("");
Serial.println("INFO: WiFi connected");
Serial.println("INFO: IP address: ");
// init the MQTT connection
client.setServer(MQTT_SERVER_IP, MQTT_SERVER_PORT);
client.setCallback(callback);
if (!client.connected())
reconnect();
client.loop();
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
delay(2000);
float p = mySensor.readFloatPressure();
float h = mySensor.readFloatHumidity();
float t = mySensor.readTempF();
if (isnan(p) || isnan(h) || isnan(t))
Serial.println("ERROR: Failed to read from sensor!");
return;
// Adjusted for elevation of 202m and converted Pa to inHg.
p = (p + 2514.05) * 0.0002952998751;
Serial.println(p);
Serial.println(h);
Serial.println(t);
publishData(p, h, t);
Serial.println("INFO: Closing the MQTT connection");
client.disconnect();
Serial.println("INFO: Closing the Wifi connection");
WiFi.disconnect();
ESP.deepSleep(SLEEPING_TIME_IN_SECONDS * 120, WAKE_RF_DEFAULT);
delay(500); // wait for deep sleep to happen
