Pulse Oximeter Simulator
I don't know if this is the right section to post this topic, but I'm just wondering do you guys have any ideas on how to make a pulse oximeter simulator using Arduino? :slight_smile:
Define "pulse oximeter simulator"
It could be a couple of seven-segment LEDs, displaying "98"
Pulse oximeter simulator - it's like a device that can be used to test the accuracy and reliability of the pulse oximeter device...
So, more of a "finger emulator" really?
finger simulator, yes. :slight_smile:
Tricky - you've got to find something that behaves to red and infra-red light like blood does.
How do you feel about animal sacrifice? :smiley:
Tricky indeed. I've been reading articles and journals about finger simulators, pulse oximeter using arduino but it seems like it making me more confused. Animal sacrifice? I hate the idea, poor animals...but if it would be the best way, I think I can handle it. :sweat_smile:
Well, at some point, you're going to have to calibrate the calibrator - you may as well bite the bullet (or the bunny!)
I honestly don't know the answer - some kind of optical filter?
Maybe get some tubes and some inks/dyes and experiment?
meinee:
I suggest you work out exactly what the sensor is sensing, and then look for some material that can provide similar properties to a finger.
I have no idea how they work, but for example if they were sensing the amount of transmitted light in a particular frequency range then it might be possible to create a graduated filter that could be moved to alter the amount of transmission in that frequency range.
All you ever wanted to know about how a pulse oximeter works;
http://www.howequipmentworks.com/physics/respi_measurements/oxygen/oximeter/pulse_oximeter.html
It looks like they compare the relative absorption of red (650nm) and infra-red (950nm) light.
So as PeterH was suggesting you need something to filter particular wavelengths.
The simplest answer is likely to be a chemical or physical one.
Perhaps you could have a test tube (finger) with different solutions that absorb different amounts of the two wavelengths, or coloured glass slides doing the same.
For example;
If you had a slides that were transparent to infrared but blocked 5% of red light you could insert slides to block 0%, 5%, 10% etc. of the red light.
Likewise you could use slides that were transparent to red light but blocked infrared light to block 0%, 5%, 10% etc. of the red light.
By combining the two slide types you could get differing ratios of red and infared light.
Actually our proposed study will use a phantom or artificial finger as a test probe. (see attachment)
I like the idea of sliding strips of ND filters in and out, the tricky bit will be getting the manufacturers to supply the data.
Wratten filters from Kodak used to be well-documented wrt wavelengths.
Anything involving liquids is going to involve flush cycles.
You need to define your requirements clearly meinee, initially you said;
Later though you show an artificial finger fitted with LEDs. That will in no way test the accuracy and reliability of the oximeter. What the artificial finger would do would be let you train people to use the equipment on a dummy with different apparent blood oxygen levels. That is a completely different requirement. It can probably be done just by varying the intensity of the red and IR LEDs on the artificial finger.
What you probably need is a rotating cylinder with a filter of some sort so that you can quickly change the absorption requirements. I don't think it will be sufficient to just calibrate the receiver, the transmitter needs calibration, too.
Given that the sensor measures attenuation (via absorption) of light produced by a pulse ox probe. Your best source for LEDs for this project may be a used pulse ox probe. As well you may be able to both sensor and emitter by using components from the pulse ox probe.
