hi i'm pretty new to arduino an try to build a pulsesensor that triggers an electromagnet. i use the pulse sensor from pulsesensor.com and trigger the 24v electromagnet with a tip120. i like the idea to not only switch on/switch off the magnet but also fade the magnet in/out with this
#define fadePin 9
void setup(){
pinMode(fadePin, OUTPUT);
void loop(){
for(int i = 0; i<360; i++){
//convert 0-360 angle to radian (needed for sin function)
float rad = DEG_TO_RAD * i;
//calculate sin of angle as number between 0 and 255
int sinOut = constrain((sin(rad) * 128) + 128, 0, 255);
analogWrite(fadePin, sinOut);
delay(3);
this works fine. now my question :).how can i insert this in the pulsesensor code that every time my heart beats the magnet is fade in/fade out.the pulsesensor code is this
long Hxv[4]; // these arrays are used in the digital filter
long Hyv[4]; // H for highpass, L for lowpass
long Lxv[4];
long Lyv[4];
unsigned long readings; // used to help normalize the signal
unsigned long peakTime; // used to time the start of the heart pulse
unsigned long lastPeakTime = 0;// used to find the time between beats
volatile int Peak; // used to locate the highest point in positive phase of heart beat waveform
int rate; // used to help determine pulse rate
volatile int BPM; // used to hold the pulse rate
int offset = 0; // used to normalize the raw data
int sampleCounter; // used to determine pulse timing
int beatCounter = 1; // used to keep track of pulses
volatile int Signal; // holds the incoming raw data
int NSignal; // holds the normalized signal
volatile int FSignal; // holds result of the bandpass filter
volatile int HRV; // holds the time between beats
volatile int Scale = 13; // used to scale the result of the digital filter. range 12<>20 : high<>low amplification
volatile int Fade = 0;
boolean first = true; // reminds us to seed the filter on the first go
volatile boolean Pulse = false; // becomes true when there is a heart pulse
volatile boolean B = false; // becomes true when there is a heart pulse
volatile boolean QS = false; // becomes true when pulse rate is determined. every 20 pulses
int pulsePin = 0; // pulse sensor purple wire connected to analog pin 0
void setup(){
pinMode(13,OUTPUT); // pin 13 will blink to your heartbeat!
Serial.begin(115200); // we agree to talk fast!
// this next bit will wind up in the library. it initializes Timer1 to throw an interrupt every 1mS.
TCCR1A = 0x00; // DISABLE OUTPUTS AND BREAK PWM ON DIGITAL PINS 9 & 10
TCCR1B = 0x11; // GO INTO 'PHASE AND FREQUENCY CORRECT' MODE, NO PRESCALER
TCCR1C = 0x00; // DON'T FORCE COMPARE
TIMSK1 = 0x01; // ENABLE OVERFLOW INTERRUPT (TOIE1)
ICR1 = 8000; // TRIGGER TIMER INTERRUPT EVERY 1mS
sei(); // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
void loop(){
Serial.print("S"); // S tells processing that the following string is sensor data
Serial.println(Signal); // Signal holds the latest raw Pulse Sensor signal
if (B == true){ // B is true when arduino finds the heart beat
Serial.print("B"); // 'B' tells Processing the following string is HRV data (time between beats in mS)
Serial.println(HRV); // HRV holds the time between this pulse and the last pulse in mS
B = false; // reseting the QS for next time
if (QS == true){ // QS is true when arduino derives the heart rate by averaging HRV over 20 beats
Serial.print("Q"); // 'QS' tells Processing that the following string is heart rate data
Serial.println(BPM); // BPM holds the heart rate in beats per minute
QS = false; // reset the B for next time
Fade -= 15;
Fade = constrain(Fade,0,255);
analogWrite(11,Fade);
delay(20); // take a break
// THIS IS THE TIMER 1 INTERRUPT SERVICE ROUTINE. IT WILL BE PUT INTO THE LIBRARY
ISR(TIMER1_OVF_vect){ // triggered every time Timer 1 overflows
// Timer 1 makes sure that we take a reading every milisecond
Signal = analogRead(pulsePin);
// First normailize the waveform around 0
readings += Signal; // take a running total
sampleCounter++; // we do this every milisecond. this timer is used as a clock
if ((sampleCounter %300) == 0){ // adjust as needed
offset = readings / 300; // average the running total
readings = 0; // reset running total
NSignal = Signal - offset; // normalizing here
// IF IT'S THE FIRST TIME THROUGH THE SKETCH, SEED THE FILTER WITH CURRENT DATA
if (first = true){
for (int i=0; i<4; i++){
Lxv[i] = Lyv[i] = NSignal <<10; // seed the lowpass filter
Hxv[i] = Hyv[i] = NSignal <<10; // seed the highpass filter
first = false; // only seed once please
// THIS IS THE BANDPAS FILTER. GENERATED AT www-users.cs.york.ac.uk/~fisher/mkfilter/trad.html
// BUTTERWORTH LOWPASS ORDER = 3; SAMPLERATE = 1mS; CORNER = 5Hz
Lxv[0] = Lxv[1]; Lxv[1] = Lxv[2]; Lxv[2] = Lxv[3];
Lxv[3] = NSignal<<10; // insert the normalized data into the lowpass filter
Lyv[0] = Lyv[1]; Lyv[1] = Lyv[2]; Lyv[2] = Lyv[3];
Lyv[3] = (Lxv[0] + Lxv[3]) + 3 * (Lxv[1] + Lxv[2])
+ (3846 * Lyv[0]) + (-11781 * Lyv[1]) + (12031 * Lyv[2]);
// Butterworth; Highpass; Order = 3; Sample Rate = 1mS; Corner = .8Hz
Hxv[0] = Hxv[1]; Hxv[1] = Hxv[2]; Hxv[2] = Hxv[3];
Hxv[3] = Lyv[3] / 4116; // insert lowpass result into highpass filter
Hyv[0] = Hyv[1]; Hyv[1] = Hyv[2]; Hyv[2] = Hyv[3];
Hyv[3] = (Hxv[3]-Hxv[0]) + 3 * (Hxv[1] - Hxv[2])
+ (8110 * Hyv[0]) + (-12206 * Hyv[1]) + (12031 * Hyv[2]);
FSignal = Hyv[3] >> Scale; // result of highpass shift-scaled
//PLAY AROUND WITH THE SHIFT VALUE TO SCALE THE OUTPUT ~12 <> ~20 = High <> Low Amplification.
if (FSignal >= Peak && Pulse == false){ // heart beat causes ADC readings to surge down in value.
Peak = FSignal; // finding the moment when the downward pulse starts
peakTime = sampleCounter; // recodrd the time to derive HRV.
// NOW IT'S TIME TO LOOK FOR THE HEART BEAT
if ((sampleCounter %20) == 0){// only look for the beat every 20mS. This clears out alot of high frequency noise.
if (FSignal < 0 && Pulse == false){ // signal surges down in value every time there is a pulse
Pulse = true; // Pulse will stay true as long as pulse signal < 0
digitalWrite(13,HIGH); // pin 13 will stay high as long as pulse signal < 0
Fade = 255; // set the fade value to highest for fading LED on pin 11 (optional)
HRV = peakTime - lastPeakTime; // measure time between beats
lastPeakTime = peakTime; // keep track of time for next pulse
B = true; // set the Quantified Self flag when HRV gets updated. NOT cleared inside this ISR
rate += HRV; // add to the running total of HRV used to determine heart rate
beatCounter++; // beatCounter times when to calculate bpm by averaging the beat time values
if (beatCounter == 10){ // derive heart rate every 10 beats. adjust as needed
rate /= beatCounter; // averaging time between beats
BPM = 60000/rate; // how many beats can fit into a minute?
beatCounter = 0; // reset counter
rate = 0; // reset running total
QS = true; // set Beat flag when BPM gets updated. NOT cleared inside this ISR
if (FSignal > 0 && Pulse == true){ // when the values are going up, it's the time between beats
digitalWrite(13,LOW); // so turn off the pin 13 LED
Pulse = false; // reset these variables so we can do it again!
Peak = 0; //
}// end isr
i hope you understand my bad english.thanks for help.
