Was just testing a ping sensor (US-100) and it is failing because of pulseIn not defined. Any idea when pulseIn will be supported in the ArduinoCore.
I see that there is an open pr in the core: zephyrCommon: Implement pulseIn · arduino/ArduinoCore-zephyr@3674743.
EDIT: Tested the US-100 with the NewPing library and that seems to work well instead of using Pulse In
May I ask how to import NewPing to AppLab?
Thank you! I used first approach and copied lib sources to subfolder inside sketch, all good - my robot can avoid obstacles now
#include <Servo.h>
#include <NewPing.h>
Servo right_servo;
Servo left_servo;
const int trigPin = 3;
const int echoPin = 4;
const int left_wheel = 6;
const int right_wheel = 10;
NewPing sonar(trigPin, echoPin, 1000);
int speed = 20; //0..90
float duration, distance = 100;
pinMode(right_wheel, OUTPUT);
pinMode(left_wheel, OUTPUT);
right_servo.attach(right_wheel);
left_servo.attach(left_wheel);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
distance = sonar.ping_cm();
if (distance > 25) {
right_servo.write(90 - speed);
left_servo.write(90 + speed);
right_servo.write(90 + speed);
left_servo.write(90 - speed);
delay(2000);
delay(200);
Also, I managed to run simultaneously webcam WebUI from object detection - it is funny to see with robot eyes
