Hey fellas, need a bit of a help here
Im currently trying to build my own flight computer (obviously simple one). I have attached 2 leds 1 buzzer and 1 button to my skech in order to change from mode to mode and see what's happening throw LED's and buzzer.
My Idea is that one push will put it into flight mode (or modeOne()
and this supposed to print new line of a data into Serial and SD card to be recorded and monitored. This is where the problem occurs: Instead of constantly repeating the same thing over and over again, prints only one line of DATA.
Two pushes will trigger Test Mode, here all okay
Holding the push button will switch all LED's off and do nothing e.g. sleep mode
Here is my complete code:
#include "I2Cdev.h"
#include "MPU6050.h"
#include "HMC5883L.h"
#include "BMP085.h"
#include "Wire.h"
#include <Servo.h>
#include "ServoEasing.hpp"
#include <PinButton.h>
#define GREEN_LED 12 // GREEN LED
#define RED_LED 31 // RED LED
#define LEFT_WING_PIN 41 // WING
#define RIGHT_WING_PIN 40 // WING
const int buzzer = 27; // Buzzer
static const float ACCEL_SENS = 16384.0; // Accel Sensitivity with default +/- 2g scale
static const float GYRO_SENS = 131.0; // Gyro Sensitivity with default +/- 250 deg/s scale
ServoEasing Left_Wing;
ServoEasing Right_Wing;
PinButton myButton(9);
// Magnetometer class default I2C address is 0x1E
// specific I2C addresses may be passed as a parameter here
// this device only supports one I2C address (0x1E)
HMC5883L mag;
int16_t mx, my, mz;
// Accel/Gyro class default I2C address is 0x68 (can be 0x69 if AD0 is high)
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
// Barometer class default I2C address is 0x77
// (though the BMP085 supports only one address)
BMP085 barometer;
float temperature;
float pressure;
int32_t lastMicros;
boolean state = HIGH;
unsigned int count = 0;
* Attach servo to pin and set servo to start position.
pinMode(RED_LED, OUTPUT);
pinMode(GREEN_LED, OUTPUT);
pinMode(buzzer, OUTPUT); // Set buzzer - pin 9 as an output
Left_Wing.attach(LEFT_WING_PIN, 4);
Right_Wing.attach(RIGHT_WING_PIN, 3);
Left_Wing.setSpeed(140); // This speed is taken if no further speed argument is given.
Right_Wing.setSpeed(140); // This speed is taken if no further speed argument is given.
delay(500); // Wait for servo to reach start position.
while (!Serial && (count < 30)) {
delay(200); // Wait for serial port to connect with timeout. Needed for native USB
digitalWrite(GREEN_LED, state);
state = !state;
count++;
digitalWrite(GREEN_LED, HIGH);
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
// ==================== MPU6050 ============================
accelgyro.initialize();
Serial.print("Testing Accel/Gyro... ");
Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
// Starts up with accel +/- 2 g and gyro +/- 250 deg/s scale
accelgyro.setI2CBypassEnabled(true); // set bypass mode
// Now we can talk to the HMC5883l
// ==================== HMC5883L ============================
mag.initialize();
Serial.print("Testing Mag... ");
Serial.println(mag.testConnection() ? "HMC5883L connection successful" : "HMC5883L connection failed");
// ==================== BMP085 ============================
barometer.initialize();
Serial.print("Testing Pressure... ");
Serial.println(barometer.testConnection() ? "BMP085 connection successful" : "BMP085 connection failed");
Serial.println("====// Setup Complete //====");
//CLOSE BOTH WINGS
Left_Wing.write(95); // Left Wing CLOSED
Right_Wing.write(0); // Right Wing CLOSED
void modeOne() {
//CLOSE BOTH WINGS
static unsigned long ms = 0;
static boolean state = HIGH;
// Serial Output Format
// === Accel === | === Gyro === | ======= Mag ======= | === Barometer === |
// X Y Z | X Y Z | X Y Z Heading | Temp Pressure |
if (millis() - ms > 100) {
// read raw accel/gyro measurements
accelgyro.getMotion6( & ax, & ay, & az, & gx, & gy, & gz);
// display tab-separated accel/gyro x/y/z values
Serial.print(ax / ACCEL_SENS);
Serial.print("\t");
Serial.print(ay / ACCEL_SENS);
Serial.print("\t");
Serial.print(az / ACCEL_SENS);
Serial.print("\t");
Serial.print(gx / GYRO_SENS);
Serial.print("\t");
Serial.print(gy / GYRO_SENS);
Serial.print("\t");
Serial.print(gz / GYRO_SENS);
Serial.print("\t");
// read raw heading measurements
mag.getHeading( & mx, & my, & mz);
// display tab-separated mag x/y/z values
Serial.print(mx);
Serial.print("\t");
Serial.print(my);
Serial.print("\t");
Serial.print(mz);
Serial.print("\t");
// To calculate heading in degrees. 0 degree indicates North
float heading = atan2(my, mx);
if (heading < 0) heading += 2 * M_PI;
Serial.print(heading * 180 / M_PI);
Serial.print("\t");
// request temperature
barometer.setControl(BMP085_MODE_TEMPERATURE);
// wait appropriate time for conversion (4.5ms delay)
lastMicros = micros();
while (micros() - lastMicros < barometer.getMeasureDelayMicroseconds());
// read calibrated temperature value in degrees Celsius
temperature = barometer.getTemperatureC();
// request pressure (3x oversampling mode, high detail, 23.5ms delay)
barometer.setControl(BMP085_MODE_PRESSURE_3);
// read calibrated pressure value in Pascals (Pa)
pressure = barometer.getPressure();
// display measured values if appropriate
Serial.print(temperature);
Serial.print("\t");
Serial.print(pressure / 100);
Serial.println("\t");
ms = millis();
void modeTwo() {
// START TESTING MODE:
Serial.println("TEST MODE STARTED");
digitalWrite(RED_LED, HIGH);
digitalWrite(GREEN_LED, LOW);
tone(buzzer, 1000); //
delay(200);
tone(buzzer, 500); //
delay(250);
delay(10);
noTone(buzzer); // Stop sound...
//OPEN BOTH WINGS
Left_Wing.write(0); // Left Wing OPEN
Right_Wing.write(105); // Right Wing OPEN
delay(2000);
//TEST LEFT WING
//TEST RIGHT WING
//CLOSE BOTH WINGS
delay(10);
delay(250);
delay(250);
Serial.println("TEST MODE FINISHED");
digitalWrite(RED_LED, LOW);
void modeOff() {
tone(buzzer, 200); //
delay(750);
myButton.update();
if (myButton.isSingleClick()) {
modeOne();
if (myButton.isDoubleClick()) {
modeTwo();
if (myButton.isLongClick()) {
modeOff();
} // close void loop
Now the code I want to run constantly when single push is made works fine on it's own, but for some reason doesn't when push button is involved.
Here is the code from the original example of GY-87
GY-87 Test
Tests basic functionality of the GY-87 sensor board.
Connections:
|== GY-87 ==|== Arduino ==|
| VCC_IN | VCC |
| GND | GND |
| SDA | SDA |
| SCL | SCL |
Requires the I2CDevLib library, which can be found here: https://github.com/jrowberg/i2cdevlib
by Tom Kuehn
26/06/2016
#include "I2Cdev.h"
#include "BMP085.h"
#include "Wire.h"
static const char LED = 12;
HMC5883L mag;
int16_t mx, my, mz;
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
BMP085 barometer;
float temperature;
float pressure;
int32_t lastMicros;
pinMode(LED, OUTPUT);
while (!Serial && (count < 30) )
digitalWrite(LED, state);
state = !state;
count++;
digitalWrite(LED, HIGH);
Wire.begin();
mag.initialize();
Serial.println("Setup Complete");
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
Serial.print(ax/ACCEL_SENS); Serial.print("\t");
Serial.print(ay/ACCEL_SENS); Serial.print("\t");
Serial.print(az/ACCEL_SENS); Serial.print("\t");
Serial.print(gx/GYRO_SENS); Serial.print("\t");
Serial.print(gy/GYRO_SENS); Serial.print("\t");
Serial.print(gz/GYRO_SENS); Serial.print("\t");
mag.getHeading(&mx, &my, &mz);
Serial.print(mx); Serial.print("\t");
Serial.print(my); Serial.print("\t");
Serial.print(mz); Serial.print("\t");
if(heading < 0) heading += 2 * M_PI;
Serial.print(heading * 180/M_PI); Serial.print("\t");
Serial.print(temperature); Serial.print("\t");
Serial.print(pressure/100); Serial.println("\t");
ms = millis();
state = !state;
Any help is much appreciated
