Push-button only works once, does not progress in duty cycle
My student has been trying several projects with his push-button, and in each case, the button turns on the music exactly once, but will not repeat the trick and play (or stop) a second time if the button is pressed again. Why isn't this if() statement working, does anyone know?
int cycles;
#define G 1567.98 //telling the arduino that G is 1567.98hz
#define B 1864.66 //telling the arduino that Bb minor is 1864.66hz
#define A 1760.00 //telling the arduino that A is 1760.00hz
#define D 1174.66 //telling the arduino that D is 1174.66hz
#define R 0 //adding a rest
  int btn = 10; //making btn a global variuable for pin 10
  int bzzr = 11; //making bzzr a global variuable for pin 11
  int notes [] = {G,B,A,D,R};//there sre the notes that i want the speaker to play
  int dur [] =   {1,1,1,1,2};//this is how long each note will play for
void setup () {
  pinMode(bzzr,OUTPUT);
  pinMode(btn, INPUT);
  cycles=0;
void loop () {
  if(digitalRead(btn)==HIGH){
    cycles=cycles+1;
if(cycles==1){
    Serial.print("hi   ");
    Serial.println(cycles);
      for(int i = 0; i < 6; i++){ //playing the music
        tone(11, notes[i], 1000);
        delay(dur[i]*900);//the amount of time in between each note
  if(cycles==2){
    cycles=0;
Show us a good schematic of the circuit.
Show us a good image of your ‘actual’ wiring.
Use CTRL T to format sketches.
Look at ‘when the switch goes HIGH’ NOT while the switch is HIGH.
The for loop is missing a closing brace.
Hi Seliaser,
when you press the button, cycles become 1, then you have an if statement, but in that statement, you don't check if the button is pressed again.
Also, you should only execute code when the button is pressed and then released, now if I hold the button, cycles will keep increasing.
I always do something like this:
/* Boolean to check if the button is pressed */
uint8_t buttonPressed = 0;
void loop () {
    /* When the button is pressed, set the boolean to true (1) */
    if(digitalRead(button)){
        buttonPressed = 1;
    /* if the button is released and buttonPressed set true */
    if (!digitalRead(button) && buttonPressed) {
    // Do your thing here
    buttonPressed = 0; // DONT forget to set this low again for next press
So also check if btn is high in if(cycles==1){}
You could try this:
int cycles;
int notes [] = {G, B, A, D, R}; //there sre the notes that i want the speaker to play
int dur [] =   {1, 1, 1, 1, 2}; //this is how long each note will play for
int buttonPressed = 0;
void setup () {
  pinMode(bzzr, OUTPUT);
  cycles = 0;
void loop () {
  if (digitalRead(btn)) {
    buttonPressed = 1;
 // When the button is released, cycles will go up one
    cycles = cycles + 1;
    buttonPressed = 0;
  if (cycles == 1) {
    // When cycles is 1, we still need to check if the button is pressed.
      buttonPressed = 1;
    // If pressed and released, cycles goes up one, then `cycles == 1` is false and we leave this part
      buttonPressed = 0;
    for (int i = 0; i < 6; i++) { //playing the music
      delay(dur[i] * 900); //the amount of time in between each note
  if (cycles == 2) {
    cycles = 0;
If I understood the question correctly, this will actually produce the wrong result... my understanding was that the music would play each time that the button is pressed.
(Using your button-pressed-and-released approach):
void loop () {
    buttonPressed = 1;
    buttonPressed = 0;
  if (cycles == 1) {
    cycles = 0;
... should do the trick I think.
I think you are right here! Should play every time the button is pressed.
int cycles;
byte btn = 10; //making btn a global variuable for pin 10
byte bzzr = 11; //making bzzr a global variuable for pin 11
byte notes [] = {G,B,A,D,R};//there sre the notes that i want the speaker to play
byte dur [] =   {1,1,1,1,2};//this is how long each note will play for
byte poll = 0;
void setup ()
  cycles=0;
void loop ()
  do
    poll = digitalRead(btn);
  }while (poll == LOW);
  playNotes ();
  delay (2000);
  playNotes ();
void playNotes ()
    //playing the music
