Please help me with this Arduino Uno push button code. By using this code when I press push button it print output continually.
But what I exactly want it when I press button (No matter its long press or single press ) it always print or serial.write only one time.
Declare a Boolean variable and set it to false. Test the variable before you print and print only if it is false. When you print set the variable to true.
Not a snowball's chance in hell. If you can't bother posting text AS TEXT, you can look for help somewhere else.
