Push button turn's on relay and a led
hi im trying to make a code to do the following
i press a push button- turn on a led and send a signal to a relay 1 seg (auto turn off) when i press the push button again the led turns off and send a signal to the relay 1seg (auto turn off)
the led part i managed to find some code in the interwebs and figure out to make it work but now i can´t figure out a way to make the relay part to work
there is my code if someone can help
const byte buttonPin = 4;
const byte ledPin = 13;
const byte relay = 5;
bool buttonState = 0;
bool lastButtonState = 0;
bool relayState = 0;
pinMode(buttonPin, INPUT_PULLUP);
pinMode(ledPin, OUTPUT);
pinMode(relay,OUTPUT);
if (buttonState = 1);
{digitalWrite (relay=1);}
delay (5);
{digitalWrite (relay=0);}
static unsigned long timer = 0;
unsigned long interval = 50;
if (millis() - timer >= interval)
timer = millis();
  buttonState = digitalRead(buttonPin);
  if (buttonState != lastButtonState)
     if (buttonState == LOW)
        digitalWrite(ledPin, !digitalRead(ledPin));
  lastButtonState = buttonState;
there shouldn't be a semicolon on the line, or other lines like this
where does timer get set?
im new to this hobby :smiley: trying to figure out what should i do then?
If something "shouldn't be there" what should you do?
If your finger is stuck in your eye, but shouldn't be stuck in your eye, what should you do?
And you prolly want ==, test for equality, not =, assignment.
Try
if(buttonState == 1)
“=“ changes the value of a variable
“==“ compares two expressions
Also, study the syntax of digitalWrite. This is wrong. Lookup examples. Do your homework.
First, you have to read the the buttonPin:
if (buttonState == 1)
updated the code with your help but now the led pin is always high and the button does not do anything (i connected a led to the relay pin (for test proposes and this one does not do anything)
pinMode(5, OUTPUT);
{buttonState = digitalRead(buttonPin);
if (buttonState == 1);
digitalWrite (5,HIGH);
delay (3000);
digitalWrite (5,LOW);
timer = millis();
if (buttonState = 0) // no semicolon, ";"
if | Arduino Documentation
still have a semicolon
what is the purpose of this timer code?
why does checking for a button strate change and press need to be in a timer?
looks like you want the timer to toggle an LED, only while a button is being pressed or when a button is pressed?
fixed it and now is working
basically i press a push button turns on and off a relay and turns on a led if i press again turns on and off a relay and turn the led off
pinMode(5, OUTPUT);
delay (200);
timer = millis();
const byte buttonPin = 4; // button wired between pin 4 and GND
bool buttonState = true;
bool lastButtonState = true;
bool relayState = false;
  pinMode(5, OUTPUT);
  if (buttonState == false)
    digitalWrite (5, HIGH);
  delay (200);
  digitalWrite (5, LOW);
    timer = millis();
I just noticed you posted the code by putting <, then pasting your code, then finishing with />.
Very creative, but that is not what the <CODE/> thing in the message composition window means, that's actually a button and when you press it, you'll see it types for you
type or paste code here
so do that, leave the backticks and paste your code over "type or paste code here", then it will look like code. @JCA34F did it for you, see how nice it looks?
And beyond looking nice, it won't get mangled. All the characters you put in there will be taken literally, so they don't end up being interpreted as formatting commands.
Next time. :expressionless:
a7
