Hi, I am trying to control 2 PWM PC fans with my Arduino Leonardo "pro micro" and a rotary encoder. I asked Chatgpt since I didn't want to code everything. It works great I can select whit fan I want to change by clicking the button and then rotate the encoder to increase or decrease the speed, but when I rotate, it detects to click if I do half-click it detect one click, which it borders me a lot, but it won't matter that much I just wonder if someone can help me.
const int encoderPin1 = 2; // CLK
const int encoderPin2 = 4; // DT
const int encoderButtonPin = 6; // SW
// Pins for fan control
const int fan1Pin = 3; // Fan 1 PWM control pin
const int fan2Pin = 5; // Fan 2 PWM control pin
// Variables to store fan speeds
int fanSpeed1 = 127;
int fanSpeed2 = 127;
// Variables to store previous positions
int prevPosition1 = 0;
int prevPosition2 = 0;
// Variable to store last time position changed
unsigned long lastChangeTime = 0;
// Variable to track active fan (1 = fan1, 2 = fan2)
int activeFan = 1;
// Initialize the serial communication
// Set encoder pin modes
pinMode(encoderPin1, INPUT_PULLUP);
pinMode(encoderPin2, INPUT_PULLUP);
pinMode(encoderButtonPin, INPUT_PULLUP);
// Set fan control pins as output
pinMode(fan1Pin, OUTPUT);
pinMode(fan2Pin, OUTPUT);
// Read the rotary encoder position
int readEncoder1(int pinA, int pinB, int prevPosition1) {
static int position1 = 10;
static int pinALast = LOW;
static int aVal = LOW;
aVal = digitalRead(pinA);
if (aVal != pinALast) {
if (digitalRead(pinB) != aVal) {
position1++;
position1--;
pinALast = aVal;
position1 = constrain(position1, 0, 25);
return position1;
int readEncoder2(int pinA, int pinB, int prevPosition2) {
static int position2 = 10;
position2++;
position2--;
pinALast = aVal;
position2 = constrain(position2, 0, 25);
return position2;
int position1 = prevPosition1;
int position2 = prevPosition2;
if (activeFan == 1) {
position1 = readEncoder1(encoderPin1, encoderPin2, prevPosition1);
} else if (activeFan == 2) {
position2 = readEncoder2(encoderPin1, encoderPin2, prevPosition2);
// Check if the position has changed for fan 1
if (position1 != prevPosition1) {
// Check if enough time has elapsed since last change
if (millis() - lastChangeTime > 125) {
// Update the previous position and last change time
prevPosition1 = position1;
lastChangeTime = millis();
// Adjust fan speed based on encoder position
fanSpeed1 = map(position1, 0, 25, 0, 255);
// Update the fan speed
analogWrite(fan1Pin, fanSpeed1);
// Print the current fan speed
Serial.print("Fan 1 Speed: ");
Serial.println(fanSpeed1);
// Check if the position has changed for fan 2
if (position2 != prevPosition2) {
prevPosition2 = position2;
fanSpeed2 = map(position2, 0, 25, 0, 255);
analogWrite(fan2Pin, fanSpeed2);
Serial.print("Fan 2 Speed: ");
Serial.println(fanSpeed2);
// Check if the encoder button is pressed
if (digitalRead(encoderButtonPin) == LOW) {
delay(250); // Delay for button debouncing
// Toggle the active fan
activeFan = 2;
Serial.println("Active Fan: Fan 2");
activeFan = 1;
Serial.println("Active Fan: Fan 1");
