I need to output a 100Hz PWM signal but the reference for the analog write says that it is fixed at around 490Hz, is there any way of changing this ? or are there alternative libraries ?
That is based on certain assumptions they made in the library. You can have other frequencies.
so I'd need to use an alternative library or function ?
