Python communication problem
I'm working on a project where the computer will be communicating with 5-6 Arduino Nanos for data acquisition.
Overview:
I send and "x" to the Arduino and the Arduino samples A0-A7 and sends back the results of all ADC as a string. The computer then loads the results to a file and acts according to the results.
Problem:
When this is powered up, Python sends the 'x' and waits forever. The Arduinos never respond. BUT..... If I open the Arduino IDE and the terminal screen in it and send an 'x', each Arduino, they work perfectly. I close the Arduino IDE and run the Python program and it works perfectly as long as it's powered up. As soon as it's powered down and back up, Python will wait forever for a response.
I've tried using only one Nano and get the same results.
What is the Arduino IDE doing that the Python program isn't when it's first connected? I want this to run at boot up for data logging.
Welcome to the forum
Please post your Arduino code, using code tags when you do
The serial monitor waits for a time after opening the serial connection so the Arduino can be reset and load a fresh copy of the program. Your Python program probably does not do that wait.
Something to study and get ideas from
Robin's examples
JML's (more recent) example
Those look like some good examples to try. Thank you!
Here is the Python I'm using. It's still a work in progress:
#!/usr/bin/python3
2024-04-28 Greenhouse controller
print("\n2024-04-28 Greenhouse controller\n")
import datetime
from datetime import time
from datetime import timezone
import time
from datetime import timedelta
import serial
from pathlib import Path
from sys import platform as _platform
import sys
import os
print(_platform)
print()
# Addresses of the Arduino boards
#gh = ['/dev/ttyUSB0']  # Test
gh = ['/dev/ttyUSB0','/dev/ttyUSB1']
#path = str("/media/rob/DATA FILES/")
path = str("/media/rob/SHOPFILES/")  # Test
def wxserial(sergh):
    #print("wxserial module")  # Test
    wxdata = sergh.readline().decode('utf-8')
    sergh.flush()
    sergh.close()
    return (wxdata)
def timeSetup():
    y = []
    # Get current times
    now = datetime.datetime.now()
    day = now.strftime('%Y-%m-%d')
    y.append(day)
    now = now.strftime('%H:%M')
    y.append(now)
    return (y)
# Save data to file
def dataSave(y, pathWrite):
    fileWrite = str(pathWrite)
    f = open(fileWrite, 'a+')
    print(y, file=f)
    f.close()
    return ()
# Main program -------------------------------------------------------------------------
print("Starting main program\n")
time.sleep(2)  # Let the Aruino boot up
while 1:
    start = time.time()
    endtime = start + 10
    y = ""
    i = 0
    times = timeSetup()
    #print("times = ", times)
    for item in gh:
        y = ''
        y = y+(times[1])
        #print("y = ", y)  # Test
        print(gh[i])
        sergh = serial.Serial(gh[i])
        if times[1] == '05:00':
            sergh.write(b'1' + b'\n')
            print("Write 1")
        elif times[1] == '21:00':
            sergh.write(b'0')
            print("Write 0")
        else:
            sergh.write(b'x')
            print("Write x")
        sergh.reset_output_buffer()
        y = y + wxserial(sergh)
        y = y[:-1]
        sergh.close()
        pathWrite = path + str('Test.csv')
        i = i+1
    while time.time() < endtime:
        pass
    end = time.time()
    print("loop = ", end-start)
    #print()
    print("--------------------------------------------------------")
That worked! Thank you very much!
