[Q] How can I convert a variable of IPAddress class to a String Object?
Why do you think you need to? An IP address is simply 4 bytes. Convert them one at a time to a string, and then append the strings.
Maybe u can resolve it with a simple cast... for example int a;String b; b = a.toString();
Well, sure. If int was a class that had a toString() method. The Arduino is NOT programmed with C#.
PaulS:
Yeah I think I will have to do something like that.. Thanks!
